Slight Cracks Between Wall And Ceiling - Painting - DIY Chatroom Home Improvement Forum
Old 03-02-2009, 02:31 PM   #1
slight cracks between wall and ceiling
I am getting ready to paint my son's room (a lot of spackling there) when I noticed some places where the wall and ceiling meet there are hairline cracks. I really, really don't want to tape and spackle unless I really, really have to. (Can you tell that is not my most favorite thing to do?)
Could I possibly put something like phenoseal in the corners and paint over? Any suggestions?
thanks in advance
deetu is offline   Reply With Quote
Old 03-02-2009, 02:32 PM   #2
Remodeling Contractor
yes that will work fine.
Old 03-02-2009, 04:21 PM   #3
www.marylandpainter.net
bikerboy's Avatar
Use a small bead of paintable caulk.
bikerboy is offline   Reply With Quote
Old 03-04-2009, 10:03 AM   #4
Matthewt1970's Avatar
Rewards Points: 1,098
Phenoseal is a brand name of Caulk which makes latex caulk so it should be fine. I do it all the time to hide cracks and clean up corners. Just make sure you smooth it out and wait atleast 24 hours before you paint it.
Old 03-04-2009, 09:42 PM   #5
thank you, thank you, thank you!
Old 03-07-2009, 03:29 PM   #6
Drywall contractor
Rewards Points: 1,070
Absolutely caulk it. It's much more flexible than joint compound. Even if you were to use joint compound (say just "finger" it in) to cover the crack, it would crack out again quicker than caulk.
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 03-07-2009, 05:53 PM   #7
Tired, Cold, and Damp
slickshift's Avatar
Unless the tape is actually failing, and it's just a crack
Caulk It!
slickshift is offline   Reply With Quote
Ceiling paint versus wall paint billyg Painting 6 02-09-2012 08:38 PM
How to diagnose problems with wall kahlan General DIY Discussions 5 10-22-2008 10:18 AM
Converting wall outlet to power ceiling light? VEIK Electrical 3 07-08-2008 09:43 AM
Wall to ceiling fw2007 Electrical 4 03-31-2008 07:18 PM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 10:11 PM
