Skimcoat Problems - Painting - DIY Chatroom Home Improvement Forum
Old 11-01-2010, 11:37 PM   #1
Exclamation
Skimcoat problems
The ceiling of my bedroom had termite damage and chipping paint, so after chipping off what I could I decided to skimcoat it. I put up adhesive mesh - with some trouble doing it alone, but eventually got the entire ceiling covered, although there are some bubbles in it.
I started skimcoating using lightweight joint compound, getting about 3 by 10 feet up, before checking out the label and realizing I was using the wrong type. I scraped off what I could, but the corner still had a pretty thick coat.
I bought all purpose joint compound, which the guy at the paint store said was fine for skim coating, with added plaster of paris.
My problem is that I don't know if it is alright to skimcoat over the lightweight compound using all purpose joint compound, or do I need to peel of the mesh and compound that I already put up, and start again.
Any help would be appreciated, thanks!
brodieb666 is offline   Reply With Quote
Old 11-02-2010, 07:05 AM   #2
DIY staff
Rewards Points: 7,174
If the lightweight stuff is sticking --you're fine---
The all purpose has glue in it and will stick well to old painted surfaces--That is what I use for the first coat-then I switch to the blue lid mud,as that is much easier to sand.--Mike--
Old 11-02-2010, 02:55 PM   #3
Thanks oh'mike!
Do you add plaster when you skim coat?
Old 11-02-2010, 04:37 PM   #4
Matthewt1970's Avatar
Rewards Points: 1,098
Your fine. You don't need to add plaster for a skim coat either, especially on a ceiling.
The Following User Says Thank You to Matthewt1970 For This Useful Post:
oh'mike (11-02-2010)
Old 11-02-2010, 07:07 PM   #5
DIY staff
Don't add plaster---
Tags
ceiling , joint compound , plaster , skimcoat
Problems with Square D Subpanel bltglt507 Electrical 16 12-04-2009 09:44 PM
Multiple problems in 3 year old house I just purchased swenard Plumbing 12 08-31-2009 04:53 PM
How to diagnose problems with wall kahlan General DIY Discussions 5 10-22-2008 10:18 AM
Elec short causing A/C problems or A/C problems causing elec problems? Marlon Electrical 2 06-25-2008 03:04 PM
Are you having ice problems? Grumpy Roofing/Siding 27 02-17-2008 04:51 PM
