Simple Spray Texture Painting Question - Painting - DIY Chatroom Home Improvement Forum
Old 05-10-2013, 11:49 AM   #1
I just fixed some wall damage. I have just finished the re-texturing of the wall. My question now is do I HAVE to prime the spot before painting? I have been told both yes and no. I have also been told that it must be oil primer. I plan on using a combined paint/primer like the rest of the house. Any guidance is appreciated!
Tom
tcharleschapman is offline   Reply With Quote
Old 05-10-2013, 11:59 AM   #2
Too Short? Cut it Again!
Yes you should prime. I don't know the texture material you used, but when in doubt, using a nice solvent based alkyd film primer like Ben Moore's Fresh Start or Zinsser Cover Stain will certainly not hurt you. Alkyd primers will go over almost anything (prepped surface of course) and you can paint near anything over them. They are the great situation equalizers in the primer world.
That said. What does the product label for the texture product recommend? Zinsser Gardz might be another option if sealing the texture is the issue. I should think a nice, high bond waterbased primer you are using elsewhere in the house could work too. Without knowing more about the texture product I cannot say for sure though.
Old 05-10-2013, 12:09 PM   #3
Thanks sdsester. Also, your avatar cracked me up.
I used Homax Brand Pro Grade Orange Peel Wall Texture. Just from a spray can. According to the instructions it says:
7. PAINT with 2 coats or more for complete hide and to match gloss (dependent upon color and paint manufacturer's instructions".
Old 05-11-2013, 01:27 PM   #4
Matthewt1970's Avatar
Rewards Points: 1,098
You are always better off using an actual primer for your first coat on any new surface.
Latex Primer: Good for Drywall, that's about it.
Behr Paint: The plastic buckets are good, that's about it.
Old 07-17-2013, 05:42 PM   #5
Thanks! I did it and it blends very well.
Spray Foam in Walls & Moisture Question leeave96 Insulation 4 11-12-2012 12:43 PM
Another Wall Texture Question angelatc Drywall & Plaster 4 11-10-2012 08:29 PM
Spray Painting without aerosol cans christina4346 Painting 4 10-05-2011 04:11 AM
several problems while texture painting ceilings and walls carrotguy Painting 2 05-25-2007 04:38 PM
Spray Texture Piney Painting 4 03-02-2007 01:24 PM
