Silicone Caulk Removal - Painting - DIY Chatroom Home Improvement Forum
Old 11-22-2010, 08:11 AM   #1
I inadvertently used silicone caulking for the crown molding. Unfortunately, paint will not adhere to it. Now I have to remove it which is not a pleasant task. I purchased a silicone gel remover from Lowes which requires 3 to 5 minutes setting time along with a tool used to remove caulk. Several applications are necessary. However, the job is extremely tedious. I'm wondering if there is a more effective product available than what I have. Please advise. Thank you
Cbarnettesq1 is offline   Reply With Quote
Old 11-22-2010, 10:31 AM   #2
KAD
Hey cbarnettesq1.
You are absolutely right about the thought that removing silicone caulking is tedious. I actually work at the Home Depot here in the Atlanta area - in the paint department, and I get this question a lot. Rather than removing the caulk I recommend priming over the already applied caulking. This will adhear to the silicone as well as giving you a solid surface for your paint to grab hold of. Just to be on the safe side, use a solvent based primer (such as: oil, shellac, or alcohol). You will only need to apply it over the caulk, so try using a small sash brush (1.5" or 2") to save time.
Have fun and let me know how it works out.
KAD is offline   Reply With Quote
Recaulking at previously silicone-caulked shower door frame hffeagan Kitchen & Bath Remodeling 37 06-05-2017 05:19 PM
Silicone caulk removal kellygreen Kitchen & Bath Remodeling 1 11-02-2010 07:20 AM
Silicone Caulk Removal Gary Osterberg General DIY Discussions 2 09-14-2010 01:01 PM
How to seal my attic access - airtight? akoch General DIY Discussions 4 09-08-2008 08:03 PM
Recaulking Bathroom Help RaeEllen Remodeling 9 07-25-2008 10:23 PM
