Sikkens Rubbol Solid Siding Finish - Painting - DIY Chatroom Home Improvement Forum
Old 08-20-2012, 02:48 PM   #1
PWT
I painted my new, never been painted or stained cedar sided lakehome 2 yrs ago with the new Sikkens Rubbol Solid Siding Finish that replaced the DEK Solid Finish. Within 3 months, it started to peel and flake off on one wall that gets southern exposure. Now, 2 yrs later, it is happening in all areas that get high-sun. I did prep it properly, using a TSP bleach solution and pressure washed it, letting it dry about a week before painting. I have been painting and staining my homes and decks for over forty years and do know what I am doing, but I have never seen a product do this. I have 2 colors on the house. The brown is peeling, the red is not. It is also not happening in shaded or covered areas....yet. Only where the sun hits it and is heavily peeling/flaking in high-sun areas. Every weekend, more seems to be peeling and flaking off. I have been told that this is a new product and have seen a few complaints on-line that are pretty much exactly like mine. Anyone here have experience with this product?
I had a Sikkens Rep out 6 weeks ago but haven't heard anything back yet. He tried to imply I didn't prep properly before painting, but that is an insult as I did and told him so, so prepping isn't an issue.
Appreciate any feedback.
Thanks!
PWT is offline   Reply With Quote
Old 08-21-2012, 12:43 PM   #2
Rewards Points: 150
Sikkens is a nightmare for all I know who use it. Now you have to strip it off which will be extremely costly. That could be reason for no call back from them.
CaptRandy is offline   Reply With Quote
Old 08-21-2012, 01:41 PM   #3
Matthewt1970's Avatar
Rewards Points: 1,098
How long was the siding up beforeyou stained it and had it turned grey already?
Latex Primer: Good for Drywall, that's about it.
Behr Paint: The plastic buckets are good, that's about it.
Old 08-22-2012, 08:57 PM   #4
Faron79's Avatar
Rewards Points: 260
Some notes here....
* Rubbol Solid-siding Finish didn't replace Solid-DEK. 2 different things there.
* Matt1970's note is important....How long was bare wood exposed??
* What kind/quality of insulation in the home?
* Did ANY TSP get dried onto the surface??
* Was any "Mill-glaze" sanded off?
Faron
Faron79 is offline   Reply With Quote
Old 08-23-2012, 12:24 AM   #5
Paint Pro
im not backing sikkens. i frankly hate sikkens. .. i only use rymar products. But,. . . . 99% off all "product failures" occur do to inadequate prep. . .or some unknown variable (heat, contamination, moisture, wood delamination, adhesion issues, vapor/solvent entrapment) and.. i hate to say it, but flaking is mainly caused by lack of surface prep. (usually). sikkens should take samples, check product batches, and figure out what exactly happened for you in their lab.
Expert Paint is offline   Reply With Quote
Old 08-23-2012, 03:59 AM   #6
paper hanger and painter
chrisn's Avatar
Rewards Points: 122
Originally Posted by Faron79 View Post
Some notes here....
Faron
that one would be my guess
Old 08-23-2012, 09:04 AM   #7
Rewards Points: 150
I would pick the mill glaze as it was new wood that he never did anything to.
vinyl Siding / Soffit Question J S Machine Building & Construction 42 04-18-2011 11:11 PM
hardie plank siding bob fortier Carpentry 4 05-31-2010 08:01 AM
Best Hidden Fastner to use on Timbertech Solid Twin Finish line Todd1 Building & Construction 1 03-10-2008 06:23 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 01:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 04:35 PM
