Sikkens Rubbol Dek Discontinued - Painting - DIY Chatroom Home Improvement Forum
Old 04-20-2010, 04:14 PM   #1
I have a deck already painted with the original oil rubbol formula from Sikkens and now I cannot get my hands on it anymore now that it has been officially discontinued. I called Sikkens and they say their Solid Dek version Oil/Acrylic version will work over the original. In your expert opinion do you think this will work and not peel prematurely on me? Wouldn't the acrylic elements in the formula not stick to the original oil finish?
equilibrium1736 is offline   Reply With Quote
Old 04-20-2010, 06:59 PM   #2
Doer of Many Things
poppameth's Avatar
Rewards Points: 576
It works fine. We've been selling the acrylic Dek and Siding products for a while now with great results over the old finishes. I've been asking those I've sold it to how things worked out because I was expecting Sikkens to drop the oil solid deck product just like they did the siding product.
poppameth is offline   Reply With Quote
Old 06-18-2010, 11:39 PM   #3
Rewards Points: 271
Are you going to clean it?
The oil/acrylic should work fine but you may want to ask them if they advise a cleaner or pretreatment.
Frank Lardino
FrankL is offline   Reply With Quote
Old 06-19-2010, 05:48 AM   #4
Doer of Many Things
poppameth's Avatar
Rewards Points: 576
Prep is the same as any other Sikkens product. The new bonds to the old without issues. Oil outside weathers down quickly enough that there aren't generally any issues with adhesion to the surface if it's cleaned properly.
Wolverine Brass - discontinued stem help ralbach Plumbing 3 03-20-2010 10:24 PM
Sears 536.884351 auger blades are discontinued, no replacement MichaelLit General DIY Discussions 2 07-08-2009 06:43 AM
I am in need of discontinued Georgia Pacific Siding!!! JPIL Building & Construction 4 07-23-2008 04:02 PM
in need of discontinued flooring for repair Creteseal Flooring 1 11-12-2007 11:25 AM
