Siding Prep - Painting - DIY Chatroom Home Improvement Forum
Old 05-29-2013, 04:21 PM   #1
Rewards Points: 32
Siding Prep
Planning to paint our home this summer. We purchased in fall of 2011. The paint is not overly bad just a lot of bad prep work in the past so there are a lot of craters and unsmooth finish. There are also areas where the paint is peeling but not too many places. We aren't overly fond of the color and this is the next project on our list.
So i did a lead test and it came back positive, almost the same color as the positive color sample. it was a klean-strip d-lead test; the one where you put some paint in the sample canister and add 5 drops shake and wait.
So there goes my plans of pressure washing the house.
My question is what options do I have? Can i just wet scrape and catch the peelings in the bad spots.; spackle the craters (no sanding), and then washing with a garden hose and detergent?
I would really like to get a paint shaver pro but $600 is a lot to drop on a tool for a DIYer like me.
Any advice is greatly appreciated.
lightsareout is offline   Reply With Quote
Old 05-29-2013, 04:24 PM   #2
cdaniels's Avatar
Homeowners can get away with some things pros can't although laws are different from state to state.I wouild check local laws to see what you can and can't do.
Charlie Daniels painting and repair
cdaniels is offline   Reply With Quote
The Following User Says Thank You to cdaniels For This Useful Post:
Gymschu (05-29-2013)
Old 05-29-2013, 05:56 PM   #3
paper hanger and painter
chrisn's Avatar
Rewards Points: 124
As a home owner, you can do anything you want, the lead laws do not apply to you.
The Following User Says Thank You to chrisn For This Useful Post:
kwikfishron (05-29-2013)
Old 05-29-2013, 07:16 PM   #4
Jmayspaint's Avatar
Rewards Points: 534
That sounds like the way to go. Except maybe substitute caulk for spackle. It's harder to make the caulk smooth, but if the house is rough already.... Caulk will also help hold everything together and will last a lot longer than spackle which is generally not for ext. applications.
Good idea to wear a thin tyvec suit during the prep to keep dust off your clothes, or at least take outer clothes off outside and wash separately. Wear a mask rated for lead dust.
Maybe look into peel bond primer to help prevent future peeling.
Jmayspaint is online now   Reply With Quote
Old 05-29-2013, 07:42 PM   #5
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 5,424
I just used that "peel stop" primer for the first time, or whatever its called, and it seemed good after applied, and after maybe 6 months, is still performing. Time will tell, but I don't see any downside to using it... except maybe cost/time... but beats complete striping.
MTN REMODEL LLC is online now   Reply With Quote
Old 05-29-2013, 08:06 PM   #6
Whether you use spackle or caulking... I'd do all of the washing first, then the filling. This is especially important if you use spackle.
clambake6 is offline   Reply With Quote
Old 05-30-2013, 08:01 AM   #7
Rewards Points: 32
Thank you for all the advice!
I realize a lot of the laws and regulations would not apply to me but i still want to do the work in a safe manor.
For the peel safe primer should i use that on the entire exterior or just the problem areas that I scrape?
Can I still use a jomax/bleach mixture for cleaning?
Another Aluminum Siding prep question aribert Painting 6 03-14-2013 02:48 PM
Prep, repair cedar siding before restaining Clicchi Painting 0 09-10-2011 06:03 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 02:07 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 01:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 04:35 PM
