Old 09-17-2010, 08:29 PM   #1
Shutter repair
Can anyone give advice how to repair the top of a shutter.
I was going to just quickly paint them but found a bolt had pulled out of one so I took them down to replace the bolt and paint them. I found it came loose because the top was rotted and wet. The tops weren't even painted.
I stupidly dug out the rot thinking I'd get to sound wood. By the time I did, I basically didn't have the top any more.
I used a hardener and filled with MH ready patch which didn't dry. I started cutting a piece of wood to replace the top piece today.
Any advice how to do this so the shutter won't fall apart when I hang it?
The middle of top and half of the right side piece next to it are rotted. Should I make 1 straight piece of wood to replace this???
These are pics before I dug out rot.
http://picasaweb.google.com/11032697...PvwouslMrt2QE#
rosemonster is offline   Reply With Quote
Old 09-20-2010, 02:46 PM   #2
NAV
Shutter repair
Sounds like you need the advice of a carpenter not a painter.
NAV is offline   Reply With Quote
Old 09-21-2010, 09:13 AM   #3
Shutter repair
Yes, this was kind of stupid and I can't figure out how to delete it.
While I was working on my front door last week, a lot of painters working at the end of my block kept stopping and telling me tips for door. Like fill with Bondo, etc. I noticed the other shutter had some pink filling as a repair that my painter did a few years ago. So I thought if I posted here, I'd get all kinds of quick advice how to fix this just enough to paint and rehang it. I would just buy a new one but it's not in budget at all.
Thanks for telling me. I'll put it under carpenter. Please disregard.
$1440+ labor only repair on 3 yr. old Goodman unit!?! JMK HVAC 23 05-06-2012 11:45 AM
Choosing a Refrigerator based on Repair Value 1655graff Appliances 5 03-01-2011 09:49 AM
Repair Compounds saggdevil Painting 3 04-25-2010 04:02 PM
What do you guys think of this roof repair job? darsunt Roofing 7 08-21-2009 09:43 PM
AC repair am I being scammed 911 hurley0351 HVAC 55 05-18-2009 09:14 AM
