Should Primer Be Tinted On New Drywall?? My Painter Says No. - Painting - Page 2 - DIY Chatroom Home Improvement Forum
Old 08-13-2012, 09:56 AM   #16
Still going...
ChrisDIY's Avatar
Rewards Points: 508
Only drawback the SW near me has bankers hours...
--Chris the DIY Guy
Working on "The Great Wall of Retaining..."
ChrisDIY is offline   Reply With Quote
Old 08-13-2012, 10:05 AM   #17
DIY staff
Rewards Points: 7,174
Same here----but I usually start early in the morning---
If cheaper paint gave me a good job I would use it--paint and labor are all included in my price---
But I always end up at Benjamin Moore or Sherwin Williams--because at the end of the job the work is faster,better and ultimately cheaper,using the more expensive paints.
oh'mike is online now   Reply With Quote
user1007 (08-13-2012)
Old 08-13-2012, 10:15 AM   #18
Too Short? Cut it Again!
Primers have many different purposes but fall into some general categories:
Stain blockers
Inhibitors
Sealers
Primers
Underlays
You may find products with a couple of these characteristics but be wary of any claiming to do all and always of those claiming to be primer and paint in one. Such products only exist for the unsuspecting public that wants magical things like one coat coverage---which used to be the hot marketing phrase.
Generally primers can be found to provide maximum adhesion to a surface and/or to provide an even base for finish coats. Primer/underlays for enamels, for example, not only assist with coverage but provide a beautiful surface for near brush stroke free finish coating.
In addition to usual applications where you need to seal new surfaces like drywall or wood trim, alkyd primers are great equalizers when switching between oil based and watebased products. You can put just about any finish over an alkyd primer.
There are also specialty primers like those self-etching for metals or for oxidation resistance. You will see discussions about restructuring sort of primers like Gardz used for things like damaged drywall surface layers and BIN for sealing hard to resolve stain issues like homes that had heavy smokers.
As mentioned, except for specialty primers, primers tend to be cheaper than quality finish coat paint so there is a practical reason for using them rather than applying extra coats of finish.
There are several on this site that refer to primers as problem solvers and there is no more true statement IMO.
Old 08-13-2012, 10:18 AM   #19
Kind of weird. They must not be doing much contractor business. Have you asked if they will deliver? Would a delivery be safe if you are not home?
Old 08-13-2012, 10:41 AM   #20
DIY staff
More like supply house hours--Open very early and close at 6;00 on some nights---
Old 08-13-2012, 11:24 AM   #21
That makes sense although they must lose some consumer business. My suppliers were very busy early in the morning filling pro orders. Most did not stay open late. My Ben Moore dealer was within a hardware franchise so was open late though.
Tags
drywall , painting , prime , priming , walls
fixing drywall after primer bullhome Drywall & Plaster 4 06-20-2012 02:29 PM
NEW DRYWALL, new addition, Need Primer chipraynor Painting 50 11-10-2011 12:45 AM
drywall primer choice autx790 Painting 16 11-08-2011 06:25 AM
primer lifts a bit of drywall mud rtoni Building & Construction 0 04-16-2010 04:36 PM
Primer Over Drywall dgoldb1 Painting 16 03-03-2008 05:37 PM
