Should I Reuse Old Trim That Has Lead Paint? - Painting - DIY Chatroom Home Improvement Forum
Old 05-27-2012, 02:57 PM   #1
Question
Should I reuse old trim that has lead paint?
I'm about to start a major renovation of an 80-year-old bungalow, including removal of interior walls. I also need to build a backyard fence, in the woods about 100 feet behind my house. The 1x6 pine planks that were used for trim in the house would be perfect for the fence, but those planks may have some lead paint on one side.
Three questions:
1) How can I tell whether they have lead?
2) If they do have lead, could I simply encapsulate the planks in paint or in an exterior varnish of some sort to prevent the lead paint from chipping into the environment?
3) Would the amount of lead in an exterior use such as that be inconsequential (i.e. isn't there a lot more lead out there simply from exterior paint on all the old houses in that neighborhood, for example?
RenewATL is offline   Reply With Quote
Old 05-27-2012, 07:56 PM   #2
DIY staff
Rewards Points: 7,174
Lead paint or not--reusing the painted pine will be a disappointment--
The paint will be very likely to peal off when exposed to the weather--
Stains 'breathe' and will allow wet wood to dry out--Paint on the other hand forms a skin that will bubble and peal when water looks for a way out of wet wood--
The Following 3 Users Say Thank You to oh'mike For This Useful Post:
jaydevries (05-27-2012), RenewATL (05-28-2012), Startingover (05-28-2012)
Tags
lead trim paint removal
Should I paint my original trim white? somecallmemike Interior Decorating 23 05-11-2012 11:22 AM
Lead Paint Removal for Homeowners Etrace0921 Painting 8 03-16-2012 09:11 PM
1st Steps in Painting? Qckrun Painting 7 12-15-2009 12:25 PM
Exterior trim paint is peeling, wood is rotting! firsthomenewb Painting 10 05-15-2008 05:04 PM
