Should I Put Polyurethine Or Varnish On Exterior Shutters? - Painting - DIY Chatroom Home Improvement Forum
Old 04-28-2012, 08:21 AM   #1
Rewards Points: 219
Should I put polyurethine or varnish on exterior shutters?
I have wood shutters on the front of the house that are made of cypress wood. They are 3 years old and were stained with an exterior stain before they were hung.
Fast forward 3 years, and the shutters are faded BAD and I have had to sand them back down and restain them.
Two questions...Will polurethane or varnish them to help protect the stain? Shouldn't the stain have lasted longer than it did?
bassadict69 is offline   Reply With Quote
Old 04-28-2012, 08:36 AM   #2
Rewards Points: 386
Hiya Bassadict...
No, in your case, neither poly, nor varnish, will protect the finish on your shutters from fading...At this stage, it'd be best if you did all your necessary surface prep (clean, sand, prime if necessary) then finish with an acrylic house paint. Acrylic house paints will hold their color and sheen far longer than stain (especially if that stain was an oil). Poly, or varnish, could actually accelerate the problem. Good luck.
ric knows paint is offline   Reply With Quote
The Following User Says Thank You to ric knows paint For This Useful Post:
bassadict69 (04-28-2012)
Old 04-28-2012, 08:53 AM   #3
Rewards Points: 219
I guess I will just have to redo them every few years... Prime and paint is out of the question! Thanks for saving me the trouble of applying something that will not help!
Old 04-28-2012, 09:19 AM   #4
Rewards Points: 386
I don't understand...the surface prep is the same whether you stain or paint. The application is the same between stain and paint. If it's necessary to apply a coat of primer, for all intents and purposes it's no different than applying a first coat of paint or stain - so why is this system out of the question?
Old 04-28-2012, 09:23 AM   #5
Rewards Points: 219
Painting is out of the question...we are going for the more natural wood look for our shutters and also the cypress porch posts which are all at the front of the house.
Old 04-28-2012, 09:25 AM   #6
Rewards Points: 386
Is the stain on the shutters a semi-transparent?
Old 04-28-2012, 09:34 AM   #7
Rewards Points: 219
Yes, it is a semi transparent oil based stain we got from a local paint store, it is supposedly sun and UV protected
Old 04-28-2012, 09:36 AM   #8
Rewards Points: 219
Old 04-28-2012, 09:42 AM   #9
Rewards Points: 386
ah - sorry, I just assumed it was a solid stain. Unfortunately, semi's don't really hold up that well to UV rays and 3 years may be about as long as you can expect. It's interesting though, UV inhibitors are expensive when added to the manufacture of an exterior coating...The industry estimates that a product with the maximum amount of UV inhibitors will lengthen the lifespan of a coating by about 10% - if a traditional ST stain lasts about 3 years, then the more expensive UV version will last about 3.5 months longer.
While there may be some ST stains that may outperform others, the most harmful element to any coating is UV light, and unfortunately the best UV blockers are those that are opaque.
Best of luck - great pics. I don't know about your area, but there are some manufacturers that make a ST Acrylic stain - Acrylics are more colorfast than are oils, but they're still semi-transparent. If you consider an acrylic, test a board first to see if it'll even provide the type of appearance you want. Sometimes they appear a little streaked.
Old 04-28-2012, 11:15 AM   #10
Rewards Points: 14,026
Concider using Tung oil.
http://www.waterlox.com/project-help...or&id=75#faq75
Old 04-28-2012, 11:22 AM   #11
Gymschu's Avatar
Rewards Points: 938
You have some great overhangs protecting your home. I would think that even a Semi-transparent stain would hold up longer than three years with that kind of protection. It doesn't appear that the shutters are getting lots of sun exposure.
Help! Walked through wet floor varnish robertsdavis Flooring 2 04-14-2012 02:55 PM
spar varnish chulett Flooring 0 08-01-2011 10:10 PM
Cedar siding problem - Varnish flaking off - need solution memento Painting 3 07-15-2011 09:58 PM
Marine Varnish?? Geaux4Tigers Painting 7 11-15-2010 09:13 PM
New Varnish crimping on floor? mikehende Flooring 2 06-18-2009 06:12 AM
