Old 06-03-2011, 08:47 AM   #1
Should I prime
I recently build a storage shed using preprimed Hardie panels. I purchased SW Duration paint. The SW salesman advised that I did not need to prime before applying this paint since it has a primer in the paint. Should I prime or not prime??
Trvlr is offline   Reply With Quote
Old 06-03-2011, 09:59 AM   #2
Should I prime
I would not - a couple good coats of the Duration and you should be done.
Old 06-03-2011, 06:40 PM   #3
Gymschu's Avatar
Should I prime
I always prime regardless. Duration is self-priming, but, to maximize performance I like primer under my paint. Another reason to prime in this instance is that Hardie Plank has had some issues with the factory applied primer. I believe there have been issues with flashing and dead spots in the finish coat that is applied over the Hardie Plank. Definitely do some research on this issue........you may even find some threads on that topic in other DIY forums.
Old 06-03-2011, 11:05 PM   #4
Super Master Painter
Ole34's Avatar
Should I prime
i always prime with latex when dealing with hardie plank..........dont know, just dont trust anything ''FACTORY PRIMED''
Ole34 is offline   Reply With Quote
Old 06-04-2011, 12:21 AM   #5
jschaben
Should I prime
If ya gotta think about it, you need to.
John Schaben
"Where all think alike, no one is thinking very much"
jschaben is offline   Reply With Quote
Old 06-04-2011, 03:21 AM   #6
Should I prime
I have used SW Duration as well as Dunn Edwards paints in similar senarios without a separate primer and with good results, but I will defer to those who perhaps have more experience than I.
Old 06-04-2011, 06:29 AM   #7
paper hanger and painter
chrisn's Avatar
Should I prime
Prime before Knockdown? finmil Drywall & Plaster 2 03-17-2010 04:32 AM
Shallow wells loses prime rosberney Plumbing 20 01-26-2010 08:56 PM
Help With Differing Opinions Re Prime Or Not By Painting Contractor jaylin Painting 8 11-23-2009 04:42 AM
to prime or not to prime? re: metal siding... annie68164 Painting 3 05-24-2009 08:58 PM
prime then texture or texture then prime jeerme Painting 8 01-23-2009 10:25 AM
