Old 04-16-2011, 04:16 PM   #1
Should I paint before I put drywall back up?
I am rehabbing a studio apartment that had some earth wood contact/ moisture mold issues. The bottom 6" of sheet rock had black mold so I cut the bottom 24" out. I am going to hit the inside of the walls (bottom plate, 2"X4" framing, back side of the wall sheeting) with a good moldicide then I was thinking of putting a coat of paint with a mild moldicide on everything before I put the sheet rock back up.
Is painting the inside of the wall a good idea to slow down future mold/rot or can it cause things to sweat or cause other problems? Is painting the back side of the sheet rock before installation ok?
Thanks for any help
Dave
Dave K is offline   Reply With Quote
Old 05-13-2011, 03:25 PM   #2
If you have a continued problem of moisture getting into your walls, then you need to fix this before you paint or drywall anything. If moisture gets in, mould will develop and rot will occur eventually. Fix the problem, then put it back together.
chrisBC is offline   Reply With Quote
Ready to paint the porch! Oil or latex? Leah Frances Painting 8 07-26-2011 08:29 PM
white streaks on paint/ drywall when touched krauseconst Painting 14 01-15-2011 10:32 AM
Textured paint over drywall lkinard1957 Drywall & Plaster 3 09-27-2010 03:12 PM
So many questions where to start?!?!(NEWBIE) painter84 Painting 5 09-15-2008 01:50 PM
Flashing NoExperience Painting 13 09-04-2008 06:56 AM
