Old 06-26-2012, 06:26 PM   #1
Shop floor
Well I couldnt decide which forum this should go in but this seems as good as any. I just completed my 12x16 wood shop and it has t&g plywood as a floor over 2x8 joists. I want to put something on the floor...stain/clear sealer/poly? Any recomendations? Id rather not paint it. Just want some protection from spills and durable.
thanks.
Chip
bullhome is offline   Reply With Quote
Old 06-26-2012, 07:55 PM   #2
sdsester's Avatar
Shop floor
Just curious why you would not want to paint it with a quality porch, floor or patio finish? Benjamin Moore's oil product is urethane reinforced and its waterborne is epoxy reinforced. Should hold up really well.
Sealer, then stain and finally polyurethane would be your other option unless you wanted to go whole hog for an two part epoxy coating.
sdsester is offline   Reply With Quote
Old 06-26-2012, 09:14 PM   #3
Rubbin walls since'79
Brushjockey's Avatar
Shop floor
I'm not a floor guy- and they do have some pretty hi test finishes that are not available on the open market- if you know of anybody in that trade it would be good to check with them.
That said- I think this is a pretty great product- as easy to apply as any waterborne- yet it dries and acts like an oil ( hybrid)
http://www.ugl.com/zarWoodFinishing/zarInteriorPolyurethane
/zarUltraMax.php
Ace hardware among others carries it.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 06-27-2012, 05:54 PM   #4
Mr. Paint's Avatar
Shop floor
Clear polyurethanes, such as Flecto Varathane, have worked well on floors. Many offer a water-base version that can be three-coated on the same day.
Mr. Paint is offline   Reply With Quote
Old 06-27-2012, 06:27 PM   #5
Shop floor
Thanks for the reply, want to avoid repainting every couple years and want to keep the "wood look' to the floor.
/zarUltraMax.php
Thanks, this looks like a good product, will it dry glossy though?...Will this be slick underfoot? Ive called around locally, looks like our local ace doesnt have it nearest is 35 minutes south of here.
Thanks. Just curious, is the advantage of water based version...dry time? Or smell... or something else? Thanks.
Old 06-27-2012, 07:13 PM   #6
Mr. Paint's Avatar
Shop floor
Yes, dry time, recoat time, low odor and non-yellowing. For the most hard finish, use clear gloss.
The Following User Says Thank You to Mr. Paint For This Useful Post:
bullhome (06-30-2012)
Old 06-27-2012, 07:21 PM   #7
Shop floor
Endure-2k or evolution from lenmar are great waterborne commercial finishes. They are owned by insl-x which is a Ben moore company - so any Ben moore dealer can get it. @90 a gal for the endure-2k. Great stuff!
mazzonetv is offline   Reply With Quote
The Following User Says Thank You to mazzonetv For This Useful Post:
Floor damage from a 2nd floor bathroom toilet leak Tamber Plumbing 3 05-03-2011 12:10 AM
Dryer duct hole thru band joist & floor joist justplumducky General Discussion 12 10-05-2010 01:31 PM
2nd floor air flow/pressure fgillis HVAC 7 02-24-2009 05:58 AM
Refinishing Painted Wood Floors MicahPDX Flooring 4 11-28-2008 11:23 AM
Levelling wood floor gomi_otaku Building & Construction 13 11-27-2008 08:45 AM
