Shiny/dull Paint - Painting - DIY Chatroom Home Improvement Forum
Old 05-25-2011, 02:39 PM   #1
shiny/dull paint
i just finished putting up new dry wall, primed and painted the walls. i'm getting shiney and dull areas on wall. roller is med. fuzzy, not foam or really long fibers. i'm using valspar semi gloss, $75.00 a gallon. i wiped down walls before priming. what am i doing wrong?
binxme8 is offline   Reply With Quote
Old 05-25-2011, 03:08 PM   #2
Gymschu's Avatar
Rewards Points: 236
Wow, paying $75 for Valspar, unbelievable. Sounds like you're not putting enough paint on the walls. Load that roller up! When you pull it up out of the paint tray it should almost, I say almost, be dripping off the roller. 3/8 inch nap is best for Semi Gloss paint.
The Following User Says Thank You to Gymschu For This Useful Post:
binxme8 (05-26-2011)
Old 05-25-2011, 03:29 PM   #3
Rewards Points: 394
If you are using a PVA primer under a semi-gloss, it may cause some flat spots, as PVA is a low-solids primer. This results in poor holdout- non-uniform sheen for the top coat. Generally, an extra topcoat will help with this problem.
Will22 is offline   Reply With Quote
The Following User Says Thank You to Will22 For This Useful Post:
Old 05-25-2011, 03:49 PM   #4
Learning by Doing
Leah Frances's Avatar
Where are you getting gouged that badly on the Valspar? I'm not a hater, but when I buy their premium interior paint I pay $45 unless I have a rebate
*edit* Canadian dollars... maybe?
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 05-25-2011, 10:16 PM   #5
I agree with Will, the primer when topcoating with semi is important. You should use a primer/sealer under a sheen finish. A flat straight primer will absorb sheen from the topcoat. You need primer with enamel holdout. I'm not as confident though that a third coat will give you a uniform appearance.
The Following User Says Thank You to jsheridan For This Useful Post:
Old 05-25-2011, 10:55 PM   #6
i did use pva primer. thanks for all the suggestions, i will try another coat of paint.
Old 05-25-2011, 11:01 PM   #7
just looked at paint can again. it's valspar sig. collection. paint and primer in 1, semi gloss.
Old 05-25-2011, 11:49 PM   #8
Rubbin walls since'79
Brushjockey's Avatar
1st- no such thing as paint and primer. New BS marketing. Use the right primer.
Second- using semi on walls is well, how can I say this tastefully...
Brushjockey is offline   Reply With Quote
The Following User Says Thank You to Brushjockey For This Useful Post:
Old 05-26-2011, 05:14 PM   #9
paper hanger and painter
chrisn's Avatar
Rewards Points: 140
and he paid $75 for it.... un freeking believable
Quick & Dirty Trim Salvage: Spackle to fill Old Chipped Paint? Lovegasoline Painting 13 09-01-2013 01:53 AM
cheap paint in bathroom got mold? mayhem69 Painting 12 05-06-2012 05:46 PM
latex paint on top of oil-based paint nancy-diy Painting 11 03-07-2010 04:02 AM
So many questions where to start?!?!(NEWBIE) painter84 Painting 5 09-15-2008 01:50 PM
Paint will not stick in Bathroom! SGTHetland Painting 9 08-18-2008 12:04 AM
