Sherwin Williams Sheen- Satin Vs Eggshell ? - Painting - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-28-2014, 12:27 PM   #16
Rewards Points: 4,780
Of course "purple" is a pretty vague term - it could mean many things given the huge color wheels available now. If it tends toward red and bright - hard to cover. If it tends toward mauve/brown and dull/gray, it can cover.
jeffnc is offline   Reply With Quote
Old 02-28-2014, 01:34 PM   #17
Matthewt1970's Avatar
Rewards Points: 1,098
Originally Posted by joewho View Post
Sherwin-Willaims is a bit different with their sheens, it goes, flat, eggshell, satin, semi-gloss, gloss and some kind of super-gloss. Their gloss is about the same sheen as others semi-gloss. SW satin will be about as flat as BM eggshell. Their paints typically run a bit flatter than others, but they have an extra gloss line. I wouldn't worry about the satin you are using. You should do some research on burnishing of the Emerald line, I've never used it. Purple will take 3 light coats. Purple will be more susceptible to burnishing...30 yr. painter, mostly with SW.
Actually I have found that to be the opposite. I remember doing a room one time where a SW eggshell met a BM Satin and the sheens were identical.
Latex Primer: Good for Drywall, that's about it.
Behr Paint: The plastic buckets are good, that's about it.
The Following User Says Thank You to Matthewt1970 For This Useful Post:
rbriggs82 (02-28-2014)
Old 02-28-2014, 02:52 PM   #18
Painting Contractor
rbriggs82's Avatar
I agree, always found SW have more sheen in comparison to other brands.
-Ryan
ParagonPainting.com
Facebook |Google+ |Twitter
rbriggs82 is offline   Reply With Quote
Old 02-28-2014, 05:20 PM   #19
Rewards Points: 5,974
The thing I agree with is sheens can be very confusing. Throw in ppg/porter, there is no sense naming them all you get the point. If the paint companies can't get it straight how are we supposed to.
The Following User Says Thank You to ToolSeeker For This Useful Post:
Gymschu (03-03-2014)
Old 02-28-2014, 05:27 PM   #20
Jmayspaint's Avatar
Rewards Points: 534
I'm sure it varies from among different lines but I have always thought SW paints tended to have less sheen than others.
To take the ambiguity out of guessing who's eggshell is shinier, or the difference between eggshell and satin, you can compare angular sheen ratings on the product data sheets.
Emerald satin happens to be almost the exact same sheen as BM Aura eggshell. Emerald satin is rated at 10-20 units @85 degrees, and Aura eggshell at 12-22 units @85 degrees. The higher the number the higher the sheen, so the Aura eggshell is a little bit shinier.
Aura satin is 28-38 @60 degrees.
"Degrees" refers to the angle that the surface is viewed from.
That's my understanding of how that works anyway.
Jmayspaint is online now   Reply With Quote
Old 02-28-2014, 05:30 PM   #21
That is interesting stuff and removes a lot of the subjectivity. Where are you finding those numbers?
Old 02-28-2014, 05:32 PM   #22
Jmayspaint's Avatar
Rewards Points: 534
Product data sheets. SW lists it as 'Finish' and BM as 'Gloss/Sheen' but its the same measurement.
Old 02-28-2014, 06:10 PM   #23
paper hanger and painter
chrisn's Avatar
Rewards Points: 124
Originally Posted by rbriggs82 View Post
Remember Regal Wall Satin Flat? It was fun explaining that to customers.
Used to be my favorite paint of all
Old 02-28-2014, 06:11 PM   #24
Painting Contractor
rbriggs82's Avatar
Me too
-Ryan
ParagonPainting.com
Old 03-03-2014, 09:51 AM   #25
Rewards Points: 394
The fact is, there is no definitive standards for sheen in paints. There are suggested ranges (Master Painters Institute- MPI gloss standards ), but different manufacturers are free to formulate their sheens as they wish. When submitting products to MPI, the product has to fit the gloss standard range as MPI designates.
Keep in mind that multiple coats of an accent color will build up mils, and also will appear to have more gloss.
Will22 is offline   Reply With Quote
The Following User Says Thank You to Will22 For This Useful Post:
Satin or Flat for Exterior Paint Sheen?? Which is most durable/protective? DamonBoost Painting 12 06-17-2015 08:28 AM
Behr eggshell is too glossy! DavidAl Painting 4 10-10-2012 12:18 PM
Questions about Sherwin Williams paint for a bathroom nitting Painting 2 03-28-2011 05:23 PM
Sherwin Williams Duration Paint Jeffery112 Painting 7 09-20-2010 01:31 AM
Sherwin Williams Duration openwaterdave Painting 0 04-15-2010 11:00 AM
