-   -   Sherwin William's Problock Primer/Bleeds? (http://www.diychatroom.com/f4/sherwin-williams-problock-primer-bleeds-72175/)
Painter10 05-27-2010 08:10 AM
I have always used problock primer, with no problems, until recently.
Did a little spackling on a ceiling...when ready, I primed.
For topcoat, and first time using Sherwin's Harmony Line (low Voc)- Flat, that problock bled through 5 top coats.
Never encountered this problem before using Problock underneath.
Curious, What could be the reason for this?
chrisn 05-27-2010 05:19 PM
What was bleeding?
Painter10 05-28-2010 07:08 AM
the problock itself was coming through.
thanks
chrisn 05-28-2010 05:31 PM
Was the primer not white? I do not understand.:huh::huh:
Painter10 05-29-2010 11:27 AM
yes, primer was white...rolled out just the spackled area, 1 coat, dried, topcoated with S.W. Harmony extra white flat...dried, you can see where the problocked spackled area comes through...and after 5 coats of Harmony.
:eek:
firehawkmph 05-29-2010 11:55 AM
Can you post some pics?
Mike Hawkins:)
racebum 05-29-2010 09:09 PM
after 5 coats? unusual. are you sure you haven't done one of the following
1. raised the area you painted giving a visual impression of a different color due to light and the height
2. lumped on so much paint in one small area the whole area is a different hue than the rest of the wall.
boman47k 05-30-2010 09:12 AM
:eek:
I think that is contributing to the problem. That and maybe the spackling not being featered out enough or a little thick.
Try feathering the patch a little more. Sand the patch if needed. Prime the whole ceiling, let dry, lightly sand the whole ceiling with the same grit, tack off, and paint with a good ceiling paint.
Maybe you used a different napped roller when you primed the patch than what was used when the ceiling was painted before and sanded it with a different grit than what was used before. You did sand the spot primer, right? If not, it may just be a case of different texture on the patch.
My .02 off the top of my head.
P.S. you did feather the primer too, right.
Painter10 05-31-2010 07:20 AM
Thanks everyone....I will look into these possibilities:yes:
