Sherwin Williams Paint For Trim/Walls Help - Painting - Page 2 - DIY Chatroom Home Improvement Forum
Old 10-21-2013, 02:13 PM   #16
Rewards Points: 119
Drawer fronts are completely flat. I think the SW SuperPaint and ProClassic are both waterborne alkyd. I'd rather save the $48 and go with SuperPaint on these cabinets. SW ProClassic is $64 a gallon, I can get a 25% off coupon.
badsha is offline   Reply With Quote
Old 10-21-2013, 09:03 PM   #17
ltd
Rewards Points: 536
no superpaint is not a water borne alkyd.pro classic is acrylic. And they also make a water bourn alkyd. I would go pro classic acrylic .as for brush marks ,good luck . I know painters that have been at it a long time that still cant lay down a great finish .of course im not talking bout me ,or the others pros on this site .but its a true skill that takes time to learn. p/s if you put any brush finish under a magnifying glass you can find fault .
ltd is offline   Reply With Quote
Old 10-22-2013, 07:12 PM   #18
Rewards Points: 119
Noted. Minor thing left is the gas heater covers/grills. I was told a special paint would need to be used. Heaters are small, 1 gravity floor and 1 wall heater. 1 Quart of paint should be enough I think. I will post some photos when I can.
Old 10-22-2013, 09:28 PM   #19
Rewards Points: 4,796
If you can remove the covers, it's a lot easier to take them to the garage and spray them. Unless you need the same color as the walls.
jeffnc is offline   Reply With Quote
Old 10-23-2013, 11:03 AM   #20
Rewards Points: 119
Yepp will be removing and having them sprayed. SW SuperPaint suffice or do I need a paint for high temps?
Old 10-23-2013, 11:38 AM   #21
Are these just vent covers for your HVAC system?
Old 10-23-2013, 11:56 AM   #22
Rewards Points: 119
No HVAC, just floor gravity heater, old school.
Old 10-23-2013, 12:09 PM   #23
I don't know. It says it can be painted over primed metal, but it doesn't mention this substrate in any of the technical directions provided. I guess I never really thought about it.
Old 10-24-2013, 01:57 PM   #24
Rewards Points: 119
Thank you all for your help. Especially Jeff. I just ordered the ProClassic for the master bedroom drawers/cabinets. I will post photos once done so you guys can see the end result.
Question on Sherwin Williams Paint mi26 Painting 10 10-17-2013 01:42 PM
Flat over Semi-Gloss dankreboot Painting 21 02-24-2013 07:46 PM
What Sherwin Williams paint is the best? gardendoc4 Painting 12 04-19-2012 03:18 AM
Do I need a primer for Sherwin Williams paint? bschuster Painting 6 03-20-2009 11:59 PM
Semi gloss on Semi gloss mattpricemn Painting 6 08-25-2008 07:18 PM
