Sherwin Williams Paint And Supplies - Painting - Page 2 - DIY Chatroom Home Improvement Forum
Old 04-03-2011, 11:48 PM   #16
Matthewt1970's Avatar
Rewards Points: 1,098
Here is the Lo-Down on tinted primer. To make it work as a first coat in a 2 coat job it needs to EXACTLY match the top coat. Not close, not even really close, it needs to be exact. Any shade of difference can #1 show through and #2 look like the topcoat would wet and lead you to have skips. Any errors can lead to a coat of tinted primer and 2 coats of finish paint when 2 coats of finish paint would have done the trick. You also need to make sure your finish coat is 100% to ensure even sheen. Even then a lot of times it isn't. If you already know you are going to need 3 coats like with certain reds and yellows, by all means, use tinted primer.
Latex Primer: Good for Drywall, that's about it.
Behr Paint: The plastic buckets are good, that's about it.
Old 04-03-2011, 11:52 PM   #17
Experienced
Jackofall1's Avatar
Yep, I have to admit, I work at a big orange store, and I won't push the P&P in one when the colors to be covered are deep toned, I won't because when they come back to get more of that big dollar paint because its not covering, they are never happy about it.
I have never had anyone come back with problems when a deep tone is covered with tinted primer and then a premium paint (I know some of you will say they don't sell any premium paint).
Is it a tad more expensive,,,,yes,,,,,does it work,,,,,,absolutely.
Old 04-04-2011, 06:15 AM   #18
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
Hey Sox Fan
You're getting good advice here from folks who are experienced with what you are proposing.
Primer & paint in one can is a no no.
Plan on prime and 2 coats. Just do it. It doesn't take that much longer.
Go to your Sherwin Williams guy and show him your before and after colors.
They will recommend tint/no tint.
Please don't second guess the tint part.
I had a room we were painting red.
Went to the S&W guy and he recommended a gray tint.
He knew what he was talking about. It worked great.
This wasn't to disagree with Mathew about exact match, just to encourage you to work with your S&W guy.
If your helpers are that insistent on 2 coats, then have the walls primed by the time they get there. I know, I know........family.....
tcleve4911 is offline   Reply With Quote
Old 04-04-2011, 06:22 AM   #19
Gymschu's Avatar
Rewards Points: 1,022
I said NOT to use primer, but after looking at the pics and those deep colors, you will have to use a primer, especially if you are making a drastic color change. As someone said, if you have semi-gloss on any of the walls, you will need to scuff sand them and apply a bonding primer so the finish coats will stick to the wall. IF it was new drywall, I would absolutely prime no matter what.
Old 04-04-2011, 07:13 AM   #20
Rubbin walls since'79
Brushjockey's Avatar
Just for the record-
one reason the paint and primer in one trick ( which was started by the marketing dept at Behr, and everyone is jumping on) is BS is because there are MANY different kinds of primers, that solve different problems.
So if you're looking at a situation to paint, think "what problem do I need to solve" to figure out what to use.
In this case, bonding is probably not a huge issue, but coverage is. A good paint will have more pigment in it than any primer and cover better, and will have no problem bonding to another latex.
If the porosity is uneven because of patching or is just wallboard and mud, sealing it up and making it even is the problem, and a good primer that was made for that should be used.
Stains have several other choices.
After stripping wallcoverings have several other choices.
Primers are not one thing . And Paint is another thing.
Some paints will adhere - so they call them self priming.
There's the cold truth.
PS- Just noticed the surface is a semi (didn't look at the pics) Priming here is a good idea for adhesion, but with a high quality paint and an overall scuff sand ( which is a good idea to get the stubble off anyway) it could go either way.
Brushjockey is offline   Reply With Quote
Old 04-04-2011, 11:56 PM   #21
Now some of you are talking about something new to me "scuffing" is this a must?
sweetredsoxfan is offline   Reply With Quote
Old 04-05-2011, 05:15 AM   #22
Scuffing is basically sanding the walls with a medium grit sandpaper. This helps with adhesion of the next coat by roughing up the surface. I would say that it is a must. Be sure to wipe off the dust before painting.
kboyz is offline   Reply With Quote
Old 04-05-2011, 09:04 AM   #23
Originally Posted by tcleve4911 View Post
Hey Sox Fan
That would fall under needing 3 coats anyways so tinted primer helps in these situations. I am refering to a 2 coat job and instead of using paint for both coats you use tinted primer for the first coat and expect only one coat of finish paint. Red's are typicly 3 coat jobs however SW has some great true red base paints now so I am surprised he didn't point you in that direction.
Old 04-05-2011, 10:51 PM   #24
My husband is going to kill me if I tell him he has to scuff, wash, prime with a tinted primer and put 2 coats on!
Old 04-06-2011, 04:12 PM   #25
Painting Company, NY
housepaintingny's Avatar
Rewards Points: 616
Originally Posted by sweetredsoxfan View Post
Should I get a tinted primer? What is a tinted primer? I thought all primers were the same..
Sherwin Williams Super Paint will cover those colors with two coats with no problems. No need to prime unless you have made repairs. Even there Promar 200 which is a lower grade would cover with 2 coats without primer.
housepaintingny is offline   Reply With Quote
The Following User Says Thank You to housepaintingny For This Useful Post:
ltd (04-06-2011)
Old 04-06-2011, 05:44 PM   #26
Rewards Points: 616
Originally Posted by spraygunn View Post
Hey sweetredsoxfan,
There are two things you might want to consider. What is the cost of primer, and what is the cost of the Super Paint. Does it make sense to put on two coats of the expensive Super Paint or one coat of primer which will seal the walls and prep them for the finish coat for less cost? This primer and paint is nothing more than a gimmick. Sherwin-Williams came out with the primer and finish in one a few years ago as a product for the contractors to be used in the new home market. Think what it saved the painting contractor with regards to his material price and labor. Behr took the concept and ran with it at Home Depot and people just ate it up.
Sherwin-Williams Pro Mar 200 primer is around $15 a gallon and the Super Paint is around $30 gallon (Iím just guessing). Do the math. If two coats will be needed, why not do it right and use the products that will give you the results youíre looking for. Your brother-in-law only wants to do you a favor and go home and youíll have to live with the results for years or wait for Sherwin-Williams to have another sale, not to mention the time it takes to repaint.
If I was bidding your home, the cheapest and best way, is to use one coat of primer and one coat of finish, I would also know the outcome and would be able to guarantee my work. Doing it your way, you can only hope for the best. Think about it.
Sherwin Williams doese not claim to substitute SuperPaint for a primer. They will even tell you that and if you read the print on the can it will tell you that. Behr came out with it first. SW and Ben Moore just followed. I don't know any contractors that apply SuperPaint in new construction. New construction homes are usually one coat of primer and two coats of contractor grade paint. If I was bidding the home I would include priming anything that needed to be primed with a quality primer and then apply two coats of SW Duration. That's what seperates some companys. Some painting companys are not looking to cut corners or be the lowest bid, but they are looking to provide a quality service and finished product, even if there bid is higher than others, because they use more expensive products.
Old 04-06-2011, 07:13 PM   #27
Paint and primer is a misleading statement, most SW paints are paint and prime in one by home depot standards, but they are never to be used directly on drywall. As another poster said, you don't need to prime if walls have been previously painted, but definitely prime any spots you use spackle in prep work.
Super paint is good paint, goes on very thick. Opulence/Cashmere is great for adult bedrooms and dining room, gives you that creamy benjamin moore look. Duration my favorite all around pound for pound paint on the market, awesome finish, coverage, and durability.
painter162 is offline   Reply With Quote
Old 04-06-2011, 07:15 PM   #28
p.s. tinted primers are only needed when applying dark colours like blacks and reds.
Old 04-07-2011, 07:55 AM   #29
Coatings Nerd
If you want the "Benjamin Moore look" why not just buy Benjamin Moore?
www.northcromwellpaint.com
Benjamin Moore, Sikkens, TWP, PPG, Airless sales and service
NCpaint1 is offline   Reply With Quote
Second layer of paint blistering DBROOKS Painting 3 03-31-2011 06:45 AM
Spot primed - baaad Dali88 Painting 19 05-01-2010 02:28 AM
Painting interior walls of a new home shuss Painting 16 12-13-2009 08:28 AM
Painting a room for new baby. Lots of questions. SuperAkuma Painting 15 01-01-2009 10:18 AM
