Sherwin-Williams Flat Superpaint Striping On Ceiling - Painting - Page 3 - DIY Chatroom Home Improvement Forum
Old 08-11-2014, 03:23 PM   #31
Rewards Points: 95
I am not a painter, but I believe a significant part of the problem is flat Superpaint with a slight sheen combined with a very smooth ceiling and large windows illuminating the ceiling. I see some here have had the same problem. Our painter wants to try and spray and back roll again with an 18 roller this time and possibly with another paint. I am thinking of trying Sherwin Williams Eminence flat ceiling paint tinted to Greek Villa to match our walls instead of the flat Superpaint that use used previously.
http://www.sherwin-williams.com/home...-ceiling-paint
Maybe we should add Latex X-tender or Floetrol to keep the paint from drying too fast.
Fire4Effect is offline   Reply With Quote
Old 08-11-2014, 03:26 PM   #32
Gymschu's Avatar
Rewards Points: 842
Emminence, I don't like Emminence on ceilings. It's worse than SuperPaint on flat ceilings.
Gymschu is online now   Reply With Quote
The Following User Says Thank You to Gymschu For This Useful Post:
chrisn (08-11-2014)
Old 08-11-2014, 05:45 PM   #33
Painting Company, NY
housepaintingny's Avatar
Rewards Points: 616
The contractor should be back rolling to begin with if he's spraying.
housepaintingny is offline   Reply With Quote
Old 08-11-2014, 05:46 PM   #34
Painting Contractor
rbriggs82's Avatar
Agreed, Emminence is the worst.
-Ryan
ParagonPainting.com
Facebook |Google+ |Twitter
rbriggs82 is offline   Reply With Quote
Old 08-11-2014, 06:44 PM   #35
Jmayspaint's Avatar
Rewards Points: 534
I actually like Eminence, but I doubt it will be the cure for this situation. It also has just a tad of sheen, especially if its tinted, and can flash if not applied just right.
Seems to me like a situation where you need cheap, dead flat paint. Master Hide as mentioned previously would fit the bill IMO.
Jmayspaint is offline   Reply With Quote
The Following User Says Thank You to Jmayspaint For This Useful Post:
ToolSeeker (08-12-2014)
Old 08-11-2014, 09:04 PM   #36
Rewards Points: 4,796
Should or should not?
jeffnc is offline   Reply With Quote
Old 08-12-2014, 08:02 AM   #37
Rewards Points: 5,974
Should, and I like the Eminence too. Anytime you spray you should bankroll, I guess I should say almost anytime you spray. The reason for this is, say on this ceiling if in the future you need to do a small repair, no matter how much you make the repair perfect, it will show really bad unless you spray it. By bankrolling you add a stipple to the paint. This way a repair can be made, then using a roller it will blend in with the rest of the ceiling
The Following User Says Thank You to ToolSeeker For This Useful Post:
housepaintingny (08-12-2014)
Old 08-12-2014, 08:12 AM   #38
It's just that he said "to begin with", and that's usually what you say when you mean you shouldn't be doing something. Looked like a typo.
The Following User Says Thank You to jeffnc For This Useful Post:
Old 08-12-2014, 10:09 AM   #39
Rewards Points: 616
I said to begin with, because the contractor should have been back rolling from the beginning of the project when he/she was spraying the ceiling.
Old 08-12-2014, 10:12 AM   #40
Gotcha.
Old 08-12-2014, 10:52 AM   #41
Rewards Points: 95
Thanks everyone for the feedback. The general consensus is to not use Sherwin Williams Eminence. Looks like we will try spraying flat Superpaint again and back roll with an 18" 1/4" nap roller sleeve. I will post the results after the ceiling is painted.
BTW, I have not received and e-mail notifications when someone has responded to this thread. I just check once a day to see if there are any responses.
Old 08-12-2014, 12:02 PM   #42
I still think 1/4" roller is part of the problem. This is a fairly large ceiling and 1/4" is a very short nap roller. When the sprayer guy goes across the ceiling what tip he uses will determine how much paint he is putting on. Then the one following comes along with this short nap roller, before he gets half way across it's full of paint. Now it can't do it's job, this can cause stripping.
Move up to a 1/2" roller cover and scrap the excess paint out of it with a 5n1 tool after a couple of trips across the room. If this is a re-paint with stipple already on the ceiling it may not need to be back rolled.
You need to subscribe to a thread to get notifications (I think)
Old 08-12-2014, 01:50 PM   #43
Rewards Points: 95
Thumbs up
Thanks, I will talk with the painter about your suggestions.
Regarding notification, I am subscribed.
Old 08-12-2014, 01:50 PM   #44
Rewards Points: 95
Does anyone have an opinion on Kelly Moore 550 flat paint for the ceiling? I would have it tinted to match the wall color. My painter is suggesting this.
Old 08-12-2014, 01:51 PM   #45
Painting Contractor
rbriggs82's Avatar
1/2 nap + masterhide = problem solved.
-Ryan
ParagonPainting.com
What Sherwin Williams Interior Line is equivalent to the A-100 Exterior Paint? arjun90 Painting 11 07-29-2012 01:19 AM
New drywall -Sherwin Williams Primer n0c7 Painting 11 12-22-2011 12:27 PM
Redoing flat ceiling to a vaulted ceiling sgtrock Building & Construction 2 02-20-2009 01:19 AM
Spray foam insulating ceiling under flat roof Jed Lukewater Remodeling 1 01-12-2009 07:22 AM
Pot lights in a drop ceiling Howdy Electrical 3 03-14-2008 08:23 PM
