Sherwin Williams Deckscapes Stain Used As Primer For Paint - Painting - DIY Chatroom Home Improvement Forum
Old 07-19-2013, 01:24 PM   #1
Sherwin Williams Deckscapes stain used as primer for paint
Hi,
I was recommended and sold Sherwin Williams Deckscapes solid color "extra white" stain to use on exterior salt treated wood as a primer. I'll be using SW A-100 "extra white" paint as the final coat.
Is it okay to use the stain as primer and would one coat stain (as primer) and one coat of A-100 paint likely be sufficient? I was planning on letting the stain/primer dry for 2 hours before coating with the paint.
Thanks for any help you can give
mrshanno is offline   Reply With Quote
Old 07-19-2013, 04:33 PM   #2
paper hanger and painter
chrisn's Avatar
Rewards Points: 504
The SW store recommended this?
chrisn is online now   Reply With Quote
Old 07-19-2013, 05:45 PM   #3
Gymschu's Avatar
Rewards Points: 934
Why bother with the paint? Two coats of Deckscapes is great protection for wood.
Old 07-19-2013, 06:32 PM   #4
Jmayspaint's Avatar
Rewards Points: 534
Originally Posted by mrshanno
Hi,
I assume your talking about a vertical surface, (that plan would be a disaster on a deck floor) and that the treated lumber has had a good amount of time (several months) to cure.
Solid stain is sometimes used for primer, I suppose there's nothing technically wrong with that system. Although Im a little surprised SW would recommend it.
Is there some extenuating circumstance that makes using stain as a primer desirable?
Or some reason you don't just use two coats of stain? Sheen maybe?
If you do go with that system, I would give the stain more time to dry. Even if the can says can be recoated in 2 hrs, that's meaning recoated with itself, not paint. To be safe, let the stain dry overnight.
Jmayspaint is online now   Reply With Quote
Old 07-19-2013, 06:33 PM   #5
Yes, the store recommended it based on what my painter sometimes uses
Old 07-19-2013, 06:34 PM   #6
Yes, it is vertical wood "louvers"...I'll give the stain more time to dry before painting
Old 07-20-2013, 01:37 AM   #7
chrisn's Avatar
Rewards Points: 504
interesting, if not somewhat surprising
Old 07-20-2013, 07:13 AM   #8
Rewards Points: 5,988
I agree. Have never heard of this. What would be the advantage? Please let us know how this comes out.
Old 07-20-2013, 09:18 AM   #9
Matthewt1970's Avatar
Rewards Points: 1,098
This, or use an actual primer.
Latex Primer: Good for Drywall, that's about it.
Behr Paint: The plastic buckets are good, that's about it.
Question on Sherwin Williams Paint mi26 Painting 10 10-17-2013 01:42 PM
So a chick walks into a Sherwin Williams store...... forcedreno2012 Painting 40 10-06-2013 11:29 AM
New drywall -Sherwin Williams Primer n0c7 Painting 11 12-22-2011 12:27 PM
Deck Staining -- compatible primer & stain issue? butterclem Painting 1 03-21-2008 08:21 PM
Porter Paint vs. Sherwin Williams vs. Benjamin Moore illinikelley Painting 6 01-03-2006 09:34 AM
