Shelves And Cure Time - Painting - DIY Chatroom Home Improvement Forum
Old 03-27-2012, 08:49 PM   #1
Rewards Points: 264
shelves and cure time
Going to paint some built in shelves and have a question about cure time. From searching the site it seems like the wait for latex to cure so you can set things on the shelves is about 30 days. Is this correct, and is acrylic included in this cure time?
Oil cures much faster, or so I read in another thread.
What about Aura? What is the cure time for Aura to be able to set things on the shelves?
7echo is offline   Reply With Quote
Old 03-27-2012, 09:12 PM   #2
Rubbin walls since'79
Brushjockey's Avatar
Although not completely correct- the words Latex, acrylic and waterborne are somewhat interchangeable.
I just did a buffet for someone- used their ...Behr.. gloss- I told them to wait at least a week- heavy stuff longer.
One trick if it is a light color is to very lightly dust it with talcum ( baby) powder.
Most paints full cure in about 3 weeks- but every day they get a bit harder. Some faster than others. I would trust Aura more than what I used..
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 03-28-2012, 04:05 AM   #3
Too Short? Cut it Again!
If you can stand flat for your shelf surfaces you will not have to wait out cure times. You will not be able to clean flat shelf surfaces like you can semi or something though. It is when you raise the sheen of latex and acrylic products to something like semi-gloss that the resins and all have to set and harden for 30 days or so.
Oils will cure faster but will take longer to dry initially. Lighter colors will yellow over time and chalking is a characteristic of oil paints on down the road. They are also more or less forbidden in many states now.
That said, I painted gallery pedestals all the time for galleries and we never were able to wait that long. Most things did not mar the finish much. Heavy pieces would sink right into the paint films though.
Old 04-02-2012, 09:45 AM   #4
Rewards Points: 394
Regular latex paints do not dry to a hard film, so they "block". For shelving, bookcases, countertops, table tops, Oil-based paints are the best choice (if they are not VOC prohibited in your area). Otherwise, use an acrylic porch/floor paint, or an industrial acrylic, which have a harder film.
Will22 is offline   Reply With Quote
Old 04-02-2012, 10:04 AM   #5
Rewards Points: 386
Will, that is great advice. Many people would never consider an acrylic floor paint because it's...well, it's for floors. But, you're right - many of the acrylic floor paints (at least the better quality ones) are harder, and far more block resistant than are the more conventional latex coatings - and they're usually available in satin or semi-gloss finishes.
ric knows paint is offline   Reply With Quote
The Following User Says Thank You to ric knows paint For This Useful Post:
user1007 (04-02-2012)
Old 04-02-2012, 08:27 PM   #6
Rewards Points: 264
Thanks for the comments.
I used BM Impervo oil, satin finish. Went on fine and looks good. I will give it a couple of weeks before putting them back in service.
Oil based dry time for book shelves? DIY DUDE Painting 4 09-01-2011 03:14 PM
