Shellac Spray Primer For Cabinets - Painting - DIY Chatroom Home Improvement Forum
Old 02-07-2011, 12:58 PM   #1
Shellac spray primer for cabinets
I am going to paint our old kitchen cabinets, and I'm planning on using BIN shellac primer. I want to use the spray can version for the fronts and backs of all the doors because it seems faster and also cleaner (no brushes to cleanup). However, every tutorial I've read says to use spray primer only for spot priming, and to roll or brush large areas. Why is brushing better? Do the spray cans leave a bad finish? Is spray painting slower than I think? I will be painting the doors outside, so ventilation is not an issue.
Thanks in advance for any advice.
pasloder is offline   Reply With Quote
Old 02-07-2011, 05:54 PM   #2
Matthewt1970's Avatar
Rewards Points: 1,098
It's just more expensive in the small spray cans. Unless you are going to end up brushing your finish coat I would go with brushing your primer. I would also switch to an oil based primer as Bin is more for stain blocking.
Old 02-07-2011, 07:17 PM   #3
I would invest a spray gun, like this one
http://www.harborfreight.com/high-vo...gun-66222.html
StevenH is offline   Reply With Quote
Old 02-07-2011, 08:12 PM   #4
ltd
Rewards Points: 536
bin spray or bin is not the best choice for priming cabinets.inmo would go with zinsser cover stain oil. this primer has more body and holds paint better . using a China bristle is recommended but i would go with a good purdy nylon polyester brush.it leaves fewer brush marks..ps. no what they claim dont use a water base primer .
ltd is offline   Reply With Quote
Old 02-08-2011, 12:27 AM   #5
paper hanger and painter
chrisn's Avatar
Rewards Points: 606
why not??
Old 02-08-2011, 10:04 AM   #6
Zinsser BIN will work fine for painting existing kitchen cabinets, that have an old finish on them. I've used it on stained, oil based painted, and new wood cabinets with great results, 2 coats will seal up anything, and BIN sticks to everything, even with minimal surface prep. Cleans up easily with denatured alcohol, or ammonia. Granted it will cost you quite a bit now with a gallon of BIN at around $40.00, but if you don't have a huge project it will work fine.
As StevenH recommended, a sprayer will do wonders as far as the finish goes, just make sure and sand between coats. Practice a bit first on some scrap, and familiarize yourself with takedown and cleaning of your spray gun, you'll never go back to brushes and rollers.
littlecleo is offline   Reply With Quote
Tags
cabinet , painting , primer , shellac , spray
Issues with primer on kitchen cabinets blinkandimgone Painting 4 08-17-2010 11:48 AM
BIN Spray Shellac-Base Primer formulation PAINTLOVER Painting 0 05-01-2010 09:54 AM
B-I-N "Zinsser" Shellac Based Primer saggdevil Painting 4 05-18-2009 05:04 AM
using BIN Shellac Base Primer Sealer joefromcal Painting 10 05-04-2009 05:47 AM
Spray primer Kilz latex now all finish paint is soft and easily peelable dorothyolive Painting 29 11-02-2008 05:14 PM
