Shellac, Is It My Answer? Neewbie Here! - Painting - DIY Chatroom Home Improvement Forum
Old 07-17-2009, 10:09 AM   #1
Shellac, is it my answer? Neewbie here!
Hey Gang,
Thanks for such a great site to ask questions... and vent frustrations!
So I am residing a section of my home that is a covered porch with 3/4" pine panels 47"x23" (the sub wall is being layered to keep the moisture out, and to insulate, so these panels are mearly for looks) These panels will be raised out from the sub-siding via painted strapping.
This area is free from the Oregon rain, but obviously can not escape the moisture content in the air, and will occasionally be hosed down to wash off dust from our gravel road. This section of house gets a fair share of afternoon sunslight.
My question is, in order to deepen the wood grain, create a gloss, and most importantly,make the panels moisture wicking free!!
Is shellac my best option?
I am sorry if there is already a thread about this, I did try a quick search! Thanks in advance for any assistance!
-the neewb!
treesmithnw is offline   Reply With Quote
Old 07-17-2009, 10:25 AM   #2
You may want to consider Sikkens, either the Log and Siding or Door and Window........heres a link to the Log and Siding:
http://www.nam.sikkens.com/product.c...egory=log-home
I believe these products would perform better than shellac in this application.
BMDealer is offline   Reply With Quote
Old 07-17-2009, 10:39 AM   #3
(the original)
Rewards Points: 756
No to the shellac for exterior use. It's still one of my favorites indoors, but needs to be protected from water spots with a coat of paste wax.
Agree on the Sikkens. Great products.
ratherbefishin' is offline   Reply With Quote
Old 07-17-2009, 10:43 AM   #4
Well geez, you guys sure don't waste time! Thanks for the tips, going to research that right now!
Thoughts on Spar Varnish?
Thanks again!
Old 07-17-2009, 10:45 AM   #5
General Contractor
You can also look into marine quality polyurethanes (used for boats). They are designed to resist water penetration and UV damage. the downside to these is they are a bit on the expensive side.
ARI001 is offline   Reply With Quote
Old 07-17-2009, 11:14 AM   #6
(the original)
Rewards Points: 756
Yup on spar varnish. Even Helmsman would probably do well in your protected area, but I'd go with Sikkens, Epifanes, or Interlux. Yeah, they're not cheap, but for this purpose you'll get a heck of a lot of years before any refinishing is needed.
Old 07-17-2009, 04:21 PM   #7
Matthewt1970's Avatar
Rewards Points: 1,098
Shellac is really for wood knots and water stains but only if you plan to paint over it.
Old 07-19-2009, 12:54 PM   #8
Boy were you guys spot on with the sikkens! We just applied to our 400 sq ft mahogany decking that is to be laid down this week, what an amazing finish in a single coat!
After all this we have decided to paint our engineered pine panel siding, but are going to sikken the plywood subwall that will show through the 1/2" spacing between the planks.
Should turn out BEAUTIFUL! (so long as I stop blowing all my cuts!)
I'll try to share some pics once the deck, soffit & siding are up!
Thanks again all for the great tip!!
Oh, and on a side note... how would you handle this situation:
I send my girlfriend down to miller paint to pick the color of sickens, and have them set her up with everything needed to get the job done, all the proper dimensions that is... Well they send her home with a 5 gallon & a 1 gallon. I question her, and she could not emphasize enough how the guys there said you absolutely need this $240 worth of stain to accomplish that size decking... we stain all the decking last night, all 4 sides, and now we have almost 5 gallons left over.
My feeling is they saw a chance to WAY oversell my unkowing girlfriend. Should I go back and raise a stink? I can see missing the mark by a gallon or two, BUT 5!!
What would you do? Since we worked out of the 5 gallon first, and will eventually use it on other things, I am going to ask them for a little credit towards the pain we need.
Old 07-21-2009, 11:05 AM   #9
If the bucket is un-opened and a factory color and not custom, they should take it back no problem. At least I would assume????
using BIN Shellac Base Primer Sealer joefromcal Painting 10 05-04-2009 06:47 AM
And they paid for this answer!! Scuba_Dave Electrical 29 02-16-2009 06:58 PM
dishwasher line froze, need answer asap TStan Plumbing 4 01-20-2009 10:00 AM
Got a Question I can't answer ladymacbeth General DIY Discussions 3 11-27-2007 11:19 AM
Insulation, simple questio - if you know the answer mt232 Building & Construction 2 07-02-2007 12:25 PM
