Shelf Life Of Paint - How To Tell - Painting - DIY Chatroom Home Improvement Forum
Old 02-26-2009, 10:30 AM   #1
Shelf life of paint - how to tell
Hi there,
I have some BM Matte latex that was mixed a year ago, 1/2 Gallon. Right color and just enough to paint the beadboard we are putting in the mudroom - how do you tell if it is still good?
I mixed it up and the paint is not separating.
What do you guys think?
Thanks again.
SandyK is offline   Reply With Quote
Old 02-26-2009, 11:03 AM   #2
(the original)
Rewards Points: 756
If it didn't freeze, it should be fine. Latex can last several years if stored properly. I like to take a piece of plastic wrap a little larger than the can and push it down on the surface of the remaining paint, then squeeze all the air out to the sides. Keeps the paint from curing in the can.
ratherbefishin' is offline   Reply With Quote
Old 02-26-2009, 11:19 AM   #3
Faron79's Avatar
Rewards Points: 260
Yep, you're good!
As Fishin' said...
if it hasn't froze, or doesn't smell bad, you're fine.
If there's still a "storable amount" left, use a glass canning-jar. The separate rubber-rimmed lid and tightening-ring make the perfect container!
Plus, you can easily see the color.
Use the smallest size for the remaining paint.
An alternative is using the slide-closing food storage bags. Place this bag-o'-paint in your jar, and you're golden! Kind of a "double-seal" goin'-on.
AIR is the enemy of stored paint.
Faron
Faron79 is offline   Reply With Quote
Old 02-26-2009, 01:05 PM   #4
Thanks guys.
Saves me some cash.
Old 02-26-2009, 07:17 PM   #5
Learning by Doing
Leah Frances's Avatar
What if it froze? Repeatedly. All winter long. Because I forgot to bring it inside.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 02-28-2009, 01:48 AM   #6
Faron79's Avatar
Rewards Points: 260
Frozen Latex=JUNK
98% of Latex paints are all done if frozen.
Most will take a "light crystallizing" freeze, BUT if it gets med/firm...game over.
Faron
Old 02-28-2009, 06:08 PM   #7
Tired, Cold, and Damp
slickshift's Avatar
It's a goner
slickshift is offline   Reply With Quote
Old 03-01-2009, 01:57 AM   #8
Matthewt1970's Avatar
Rewards Points: 1,098
I have had a few cans freeze and still be ok, but they weren't frozen solid. A good Idea is every change of the season go to every can of paint you have stored and shake them up real good.
Old 03-02-2009, 02:04 PM   #9
Its not true that paint is garbage if frozen .Call your sales rep and ask him for the freeze-thaw cycle of the paint ,Some paint can be frozen and thawed up to 5 times before they are garbage
torpainter is offline   Reply With Quote
Flat over Semi-Gloss dankreboot Painting 21 02-24-2013 08:46 PM
Dark over light...Do I need tinted primer? melissaandkris Painting 17 09-09-2011 11:43 AM
semi gloss enamel vs eggshell enamel NoExperience Painting 18 03-05-2009 05:57 AM
Flashing NoExperience Painting 13 09-04-2008 06:56 AM
Semi gloss on Semi gloss mattpricemn Painting 6 08-25-2008 08:18 PM
