Sheetrock Nails Holes - Painting - DIY Chatroom Home Improvement Forum
Old 02-26-2014, 07:49 PM   #1
sheetrock nails holes
Getting ready to paint the walls and want to fill in some small nail holes where pictures were hanging. Whats the easiest thing to use to fill the holes?
mopower440 is offline   Reply With Quote
Old 02-26-2014, 08:16 PM   #2
Jb1234's Avatar
Rewards Points: 87
Spackle. Make sure you prime or the paint might not come out even or the same sheen over the spackle.
Jb1234 is offline   Reply With Quote
Old 02-26-2014, 08:27 PM   #3
Rewards Points: 13,468
Lightly sand first with a sanding sponge first. Just enough to knock off raised area.
All you want to do is fill the tiny hole, not have it all over the wall unless there's a low spot where the hammer missed or there's peeled paint.
If that's the case then you would want to use a 4" wide putty knife.
Old 02-26-2014, 09:33 PM   #4
Gymschu's Avatar
Rewards Points: 678
This stuff:
The Following User Says Thank You to Gymschu For This Useful Post:
rbriggs82 (02-26-2014)
Old 02-26-2014, 10:52 PM   #5
Painting Contractor
rbriggs82's Avatar
Originally Posted by Gymschu View Post
This stuff:
I second that.
Don't forget to prime the spots before painting or it will flash.
-Ryan
ParagonPainting.com
Facebook |Google+ |Twitter
rbriggs82 is offline   Reply With Quote
The Following User Says Thank You to rbriggs82 For This Useful Post:
Gymschu (02-27-2014)
Old 02-27-2014, 06:30 AM   #6
Jmayspaint's Avatar
Rewards Points: 534
Or this stuff. It's a little denser and doesn't flash as bad.
Jmayspaint is offline   Reply With Quote
Old 02-27-2014, 07:48 AM   #7
Rewards Points: 5,974
Has anyone tried the new 3M, I think it is, that has the primer in it LOL. I know I know but it really seems to work.
Old 02-27-2014, 10:15 AM   #8
Painting Contractor
Rewards Points: 87
I tried the 3M as a free sample from Sherwin Williams. Did not like it, and remember I would never buy it, but don't remember the specific reason. It may be that I fill nail holes by swiping some on the hole with my fingertip, so only the hole itself gets filled. I think that product did not spread well that way, or dried too quickly to use that way. The lightweight was my favorite, but just switched to the pink one that dries white. It is more of a DIY type spackle, but I like the density of it and the way it sands. Also with the finger swipe method I do not need to prime those spots since the spackle spot is so small it is not noticeable.
Hate it when customers pre spackle holes before i arrive with big globs that I have to spend time sanding down.
kkeith is offline   Reply With Quote
The Following 2 Users Say Thank You to kkeith For This Useful Post:
Gymschu (02-27-2014), ToolSeeker (02-27-2014)
Replacing Sheetrock Window Trim with Wood - NEWB Alert - Please Help! Mark79 Remodeling 7 01-24-2012 11:37 AM
Used wrong nails for joist hanger odlaw Remodeling 14 05-28-2011 10:26 AM
nail guns & nails koodawg Tools 4 12-06-2010 10:05 PM
insulation types i can use between current and new sheetrock on ceiling philbee62 Remodeling 4 08-05-2010 07:12 PM
Sheetrock put on w/o removing door trim Carla33 Carpentry 13 12-26-2009 01:32 AM
