Sheetrock Damage From Wallpaper Removal - Painting - Page 2 - DIY Chatroom Home Improvement Forum
Old 07-03-2011, 05:24 AM   #16
paper hanger and painter
chrisn's Avatar
Rewards Points: 294
Originally Posted by m1951mm View Post
I agree that Guardz is wonderful for a seal coat on damaged drywall. I do not agree that it seals wallpaper glue all that well. I stripped a bathroom, had lots of wall damage so I knew I would need to use the Guardz. The label says that it will seal the paste, so I did not try to get ALL the glue off, but it did not. Since I was doing a venetian plaster finish on the walls, I knew I did not need the surface to be perfectly smooth. After priming with Guardz the plaster bubbled up on me. In the future I will always use an oil primer to seal in any wallpaper glue that just did not want to come off. Just my two cents.
Don't make me go there. please.
Old 07-03-2011, 07:19 AM   #17
Rubbin walls since'79
Brushjockey's Avatar
m1951- All of us who recommend Gardz say to a person to remove the paste first. If you are doing what you did, I would have used 2 coats .
But I have also seen oil fail both at sealing paste and sealing damages wallboard. It depends on how completely and thickly it has been covered.
Brushjockey is offline   Reply With Quote
Wallpaper Removal Choices in Kitchen LeviDIY Painting 14 12-02-2011 03:30 AM
Wallpaper removal and lead paint risk? rhena Painting 12 06-07-2011 04:30 PM
Wallpaper removal or primer? Should I put up new wallpaper instead? Aqua Painting 1 04-06-2011 04:36 AM
Wallpaper Removal saggdevil Painting 1 06-01-2009 04:31 AM
Drywall or Wallpaper removal? Slicendice Remodeling 3 03-16-2005 05:41 PM
