-   -   sheetrock (http://www.diychatroom.com/f4/sheetrock-6458/)
TonyD 02-12-2007 10:44 AM
sheetrock
I am putting up new sheetrock on a kitchen ceiling.. Accidentally I made some cutouts reversed. Instead oF tossing the sheet can I install it on the opposite side (dark Paper side facing down ). Will It make a difference. Any thoughts on this.
tony
KUIPORNG 02-12-2007 11:03 AM
not a good idea
considering sheet rock only 10 bucks a piece... I would get new ones and use your wrong cut out to mould it on the new sheet rock to save measuring time ... Although I have never try it... but the paper in the back and front is of different texture... it probably affect the decorating look... I wouldn't risk that....
cibula11 02-12-2007 01:48 PM
I guess I wouldn't try it either. Think about it if you put it up and had it all finished, then when you went to paint, that area looked a lot darker. It would not pay off.
Hindsight is 20/20
TonyD 02-12-2007 08:38 PM
Thanks Guys,
I kinda thought the same thing, but I guess I just needed to hear it.
TonyD
AtlanticWBConst. 02-12-2007 09:34 PM
tony
Even the pros make that mistake now and then....
TonyD 02-13-2007 09:47 PM
When they make that mistake , they take it down too I guess.
TonyD
AtlanticWBConst. 02-13-2007 11:07 PM
TonyD
Smooth-sanded surface: Yes...taken down....
Textured ceiling: No...it can be completely 'textured' over ...and look/be 100 %... (spoken from experience)
