Sequence Of Brush Painting Corners Vs Rolling Main Areas - Painting - DIY Chatroom Home Improvement Forum
Old 04-21-2013, 09:40 PM   #1
Rewards Points: 1,062
Question
Sequence of brush painting corners vs rolling main areas
Does it matter whether drywall corners get brush painted first or the main areas (rest of wall/ceiling) painted with a roller? I understand that the brush is more prone to leaving streaks, that is why i put my judgment on corners brushed first and then rolling as close to the corner as possible, overlapping some brush paint.
Old 04-21-2013, 09:52 PM   #2
Brush then roll. On low budget rush jobs you can save time by rolling first then cutting in, but generally brush first roll second.
The Following User Says Thank You to jsheridan For This Useful Post:
amakarevic (04-21-2013)
Old 04-21-2013, 09:54 PM   #3
yep, that's exactly what i thought. thanks for confirming.
Old 04-21-2013, 10:50 PM   #4
Question
hey, one more question: if, after the first coat, the brushed bead around the corners looks thicker than the rolled coat in the main areas, do you think i should skip brushing the 2nd coat and just roll over the main area in the middle? or should i brush 2nd coat nonetheless? i am afraid of tone imbalance because i think the brush applies too much paint. my brush is an anged 2.5" Purdy (the most popular Purdy).
Old 04-21-2013, 10:58 PM   #5
Rewards Points: 13,300
Once it all drys you'll end up with shadows in the corners without that second coat.
Old 04-21-2013, 11:00 PM   #6
Question
so do the 2nd coat in corner with the brush or not?
Old 04-21-2013, 11:54 PM   #7
Yes with a brush.
Old 04-22-2013, 05:22 AM   #8
paper hanger and painter
chrisn's Avatar
Rewards Points: 234
believe it or not the roller is putting on more paint than the brush( if you are painting properly)
Old 04-22-2013, 06:28 AM   #9
Ama, brush and roller do each give a different texture/look, with the roller looking more uniform. If you brush after rolling your edges will have a less uniform look. It can be a small difference or a bigger difference depending on the sheen, color, and how wild you are. I feather my cut in as much as possible and I try to keep my roll edges uniform and straight.
Old 04-22-2013, 02:09 PM   #10
Matthewt1970's Avatar
Rewards Points: 1,098
For the DIYer always cut then roll. Reason being is the roller blends into the brushed area and is less likely to flash (uneven sheen).
Latex Primer: Good for Drywall, that's about it.
Behr Paint: The plastic buckets are good, that's about it.
The Following 2 Users Say Thank You to Matthewt1970 For This Useful Post:
amakarevic (04-22-2013), ToolSeeker (04-22-2013)
Tags
paint
painting large areas farrington135 Painting 10 02-17-2012 06:52 PM
Best way to cut in and not leave brush marks? twilightcall Painting 14 02-17-2012 04:19 AM
painting over repaired areas on drywall sandymc Painting 3 08-22-2011 05:20 PM
Tips for painting outside corners without edge buildup? gmhut Painting 2 05-04-2009 07:16 PM
Brush marks when painting roof HELP Toymit Painting 5 03-09-2009 03:48 AM
