-   -   Sequence of brush painting corners vs rolling main areas (http://www.diychatroom.com/f4/sequence-brush-painting-corners-vs-rolling-main-areas-177773/)
amakarevic 04-21-2013 08:40 PM
Does it matter whether drywall corners get brush painted first or the main areas (rest of wall/ceiling) painted with a roller? I understand that the brush is more prone to leaving streaks, that is why i put my judgment on corners brushed first and then rolling as close to the corner as possible, overlapping some brush paint.
jsheridan 04-21-2013 08:52 PM
Brush then roll. On low budget rush jobs you can save time by rolling first then cutting in, but generally brush first roll second.
amakarevic 04-21-2013 08:54 PM
yep, that's exactly what i thought. thanks for confirming.
amakarevic 04-21-2013 09:50 PM
hey, one more question: if, after the first coat, the brushed bead around the corners looks thicker than the rolled coat in the main areas, do you think i should skip brushing the 2nd coat and just roll over the main area in the middle? or should i brush 2nd coat nonetheless? i am afraid of tone imbalance because i think the brush applies too much paint. my brush is an anged 2.5" Purdy (the most popular Purdy).
joecaption 04-21-2013 09:58 PM
Once it all drys you'll end up with shadows in the corners without that second coat.
amakarevic 04-21-2013 10:00 PM
so do the 2nd coat in corner with the brush or not?
joecaption 04-21-2013 10:54 PM
Yes with a brush.
chrisn 04-22-2013 04:22 AM
believe it or not the roller is putting on more paint than the brush( if you are painting properly)
jsheridan 04-22-2013 05:28 AM
Ama, brush and roller do each give a different texture/look, with the roller looking more uniform. If you brush after rolling your edges will have a less uniform look. It can be a small difference or a bigger difference depending on the sheen, color, and how wild you are. I feather my cut in as much as possible and I try to keep my roll edges uniform and straight.
Matthewt1970 04-22-2013 01:09 PM
For the DIYer always cut then roll. Reason being is the roller blends into the brushed area and is less likely to flash (uneven sheen).
