Semi Gloss In White And Spackle Spots Have NO Gloss - What's Happening Here? - Painting - Page 3 - DIY Chatroom Home Improvement Forum
Old 07-30-2013, 08:08 PM   #31
Rewards Points: 38
It seems like the PVA sealed the joint compound (hot mud) the best of the 4 I tried (all 3 Valspars at Lowes and the Zinsser). All of them covered in the ok range. None of the Valspar Latex primers (other than the PVA) sealed worth a darn in my experience. They joint compound just kept on drinking it up. I read a trick that if you add Elmers Glue to the joint compound when wet it'll be easier to seal. May try that next time. But for now it seems that the PVA was the way to go.
With any shine (semi gloss etc) sealing is much more important than I would have ever given it credit for in painting drywall. Live and learn.
777funk is offline   Reply With Quote
Old 07-30-2013, 08:46 PM   #32
Painting Contractor CT
Rewards Points: 77
Post
What's happening here?
That's all it is, should have applied primer before painting spackled areas.
KD PAINTING is offline   Reply With Quote
Old 07-30-2013, 09:40 PM   #33
Rewards Points: 38
Yes, we did. We used the primer listed in the 1st post.
Old 07-31-2013, 02:17 AM   #34
paper hanger and painter
chrisn's Avatar
Rewards Points: 394
If the 123 did not seal it, then you are not applying it correctly, (imo)
Old 07-31-2013, 04:40 AM   #35
Rewards Points: 38
I didn't say it didn't seal it. But I said the primer in the first post and the other Latex Valspar primers didn't seal.
Old 07-31-2013, 07:37 AM   #36
Rewards Points: 5,974
A lot of us add glue to compound but it's for strength. Really don't know of the effect on priming.
Old 07-31-2013, 09:12 AM   #37
Rubbin walls since'79
Brushjockey's Avatar
Wait..Tool..what?
What glue do you add to mud? I have never even heard of that>?
Interesting idea- just not sure how that would be any better than just using a hot mud, which is pretty darn strong.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
The Following User Says Thank You to Brushjockey For This Useful Post:
chrisn (07-31-2013)
Old 07-31-2013, 04:56 PM   #38
If all you have is bucket mud on the site to save time from going to get hot mud you would use the bucket mud with a little glue in it. Now keep a bottle of mud max in the truck serves the same purpose. If you have an odd angle and are worried it may have crack problems mix some glue in your hot mud or mix your hot mud with mud max. If you just want your corners to be a little stronger mix some glue or mud max with the mud. Even for bucket mud this adds a lot of strength just don't use it on final coat as it does make sanding harder. If you don't have the mud max just regular white glue will do.
Old 07-31-2013, 07:11 PM   #39
OK- googled Mud Max- never ran into this stuff. See! learn something new!
http://www.all-wall.com/Categories/D...-Max-Pint.html
Old 07-31-2013, 07:31 PM   #40
Jmayspaint's Avatar
Rewards Points: 534
Yea, that's cool. I've heard drywall guys talk about using hardener on crack prone areas.
I wondered what it was.
Jmayspaint is offline   Reply With Quote
Old 08-19-2013, 12:42 PM   #41
777funk, here are my 2 cents, most of which has already been posted here. I have done painting on and off since I was a teenager (58 now) and have tried to learn along the way. I did a kitchen years ago that had a semi-gloss on it already, the tenant wanted it repainted with semi-gloss. I patched and painted and the patches REALLY stood out because I did not prime! I am at the point where I ALWAYS double prime patching so that I don't get flashing. I have used a lot of Kilz 2 lately because I am doing mostly paint-to-make-look-good-and-sell properties, the customers want as low a price as I can give, and Kilz 2 is generally on sale at Home Depot for under 25 for 2 gallons. For customers that want to live in their homes after the painting is done I might go with Aqua-Lock primer/sealer.
Whatever primer you use on patched spots, make sure it will seal the spackling compound so that the paint lays on top and does not absorb into the spackling. And remember to double prime your spackling. Better safe than sorry IMO.
Fred
futtyos is offline   Reply With Quote
Old 08-19-2013, 09:36 PM   #42
Rewards Points: 4,796
[reply to old post]
jeffnc is offline   Reply With Quote
Wall/Paint and Spackle Spots I will try to make this short... cluelessathome Painting 8 11-29-2010 10:30 AM
