Semi Gloss In White And Spackle Spots Have NO Gloss - What's Happening Here? - Painting - Page 2 - DIY Chatroom Home Improvement Forum
Old 07-26-2013, 02:58 PM   #16
Rewards Points: 38
Thanks Will22 and all who've replied.
Will the joint compound has cured for about 3 weeks in this case.
777funk is offline   Reply With Quote
Old 07-26-2013, 04:49 PM   #17
Matthewt1970's Avatar
Rewards Points: 1,098
Originally Posted by jeffnc View Post
You can ignore brands and try to learn more about which actual paint is quality. Because there is no such thing as "Sherwin Williams paint". Sherwin Williams makes crappy paint and good paint, just like Benjamin Moore, etc.
There are dogmatic people here who will tell you that Sherwin Williams paint is great, and Behr paint isn't worth the cost of the can it comes in. This is nonsense of course. It depends on which paint you're using and for which purpose.
If you had a bad experience with Sherwin Williams paint, then either you used a poor Sherwin Williams paint, or it was a difficult or incompatible situation. At $50/gal, the paint itself was likely not the problem.
The fact is, in this case it's not the brands per se that are causing you problems. Having said that, I doubt Walmart has a lot of quality paint, but it really doesn't matter what paint you use - if the patch has been applied correctly and sealed correctly, not even the cheapest paints should flash.
I will take the crappiest of Sherwin Williams paint over the very best of Behr all day long.
Latex Primer: Good for Drywall, that's about it.
Behr Paint: The plastic buckets are good, that's about it.
Old 07-26-2013, 09:38 PM   #18
Rewards Points: 4,796
Originally Posted by 777funk View Post
I should add that the SW paint we used was yellow over an old color with a lot of red in it so it did have a challenge as far as hiding the old. But regardless, washability (even a small food stain from kids) was not good at all. This was Satin but was advertised as a very washable paint.
A quality satin should be easy to clean, so not sure what went wrong there. Colorwise, yellows and reds are usually the hardest to cover with. When you get into the deep bases, it's like a different paint altogether. For example, let's say you're using SuperPaint, but in deep color. I call them "clear" colors because they can't use the same white base that gave the paint its reputation - the color just can't take that much titanium dioxide, so it simply isn't opaque any more. It comes in a different can and is simply a different paint as far as I'm concerned.
jeffnc is offline   Reply With Quote
Old 07-26-2013, 09:44 PM   #19
I'm sure you would, and that would be a very bad example for homeowners to follow. Behr Premium Plus Ultra blows ProMar 700 out of the water in every performance category imaginable. Well, maybe if you're counting on high splatter as part of some strange faux finish then ProMar might be better. Claims that a paint like ProMar 700 is somehow better than Premium Plus Ultra is simply based on pure dogma, not on facts.
Old 07-26-2013, 10:28 PM   #20
You mean the Behr Premium Plus that actually stays on the wall or the portion that saggs off? SW will steer the general public away from Promar 700 and only reluctantly sell the Promar 200. Promar 200 at $20/Gallon will blow away anything Behr can put in a can. My claim are based on years of experience from both paints, not one weekend job from a plumber.
Old 07-27-2013, 01:27 AM   #21
cdaniels's Avatar
cdaniels is offline   Reply With Quote
Old 07-27-2013, 01:37 AM   #22
paper hanger and painter
chrisn's Avatar
Rewards Points: 602
really?
is that like your other statement
quote"Because there is no such thing as "Sherwin Williams paint".
The Following User Says Thank You to chrisn For This Useful Post:
Matthewt1970 (07-27-2013)
Old 07-28-2013, 07:06 AM   #23
Rewards Points: 6,034
What I think happened is the hot mud. Hot mud can absorb paint quite differently depending on who mixed it and how much water they used. That is one reason why pro's almost always cover hot mud with a topcoat of regular mud.
Old 07-28-2013, 12:00 PM   #24
Regular mud always tends to be smoother and is easier to sand.
Old 07-28-2013, 12:13 PM   #25
Rewards Points: 38
I just did a bunch of reading on contractor talk and paint talk forums and other places and it looks like a lot of the pros use 5, 20, and 45 minute hot mud for filling nail holes and dents.
It's not a texture problem I'm having, it's that the mud is drinking up the topcoat and not allowing enough surface build to have a sheen/gloss.
My bet right now is on the primer sealer. It seems like anywhere we didn't mud looks great. It's just the dent fills that are still showing as flat/low sheen spots. I am going to try a PVA primer and see if that does the trick.
Old 07-28-2013, 01:03 PM   #26
Yep, I always use 45 or 90 for my first coat. It's a much stronger product but like it said it doesn't smooth out as well or is as easy to sand as regular mud. PVA is not a very popular primer by the pros, myself included as it doesn't seem to do a whole heck of a lot but at this point you just need to build up the surface so anything will help.
Old 07-28-2013, 01:30 PM   #27
cdaniels's Avatar
You need something that seals better than a PVA but with all the paint and primer you have on it it should be sealed by now.
Charlie Daniels painting and repair
Old 07-29-2013, 02:05 PM   #28
Rewards Points: 38
I purchased small quantities of Valspar PVA, Valspar Latex Primer for New Drywall, and Zinser 3,2,1 and have some fresh test spots to try them on to see how they do vs the high hiding primer we had tried first. Also as far as hiding properties, so far the PVA primer seems to cover a dark color (dark grey) just as well as the "high Hiding".
Old 07-30-2013, 06:06 PM   #29
Rewards Points: 38
Just did some experiments and these were just in two test areas (not whole rooms yet) but it seems like PVA primer sealed the patches better than Latex Primers (Valspar in both cases). The Zinser 1,2,3 also did a nice job. I'd say the PVA is probably what we'll be using for the rest of the project though due to price. It seems to get the patches sealed.
Old 07-30-2013, 06:31 PM   #30
Rubbin walls since'79
Brushjockey's Avatar
Don't look to primers to 'cover". That's not what they do- but seal- yes.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Wall/Paint and Spackle Spots I will try to make this short... cluelessathome Painting 8 11-29-2010 10:30 AM
