Semi Gloss Too Glossy - Painting - DIY Chatroom Home Improvement Forum
Old 11-28-2011, 08:48 AM   #1
semi gloss too glossy
How can we get some of the gloss off our newly painted semi gloss walls?
ettellamp is offline   Reply With Quote
Old 11-28-2011, 09:35 AM   #2
Welcome ettellamp, simple answer, paint them with a lower gloss paint. Not to sound like a wise a$$.
Joe
Old 11-28-2011, 06:14 PM   #3
Rewards Points: 386
Hiya Et...
If you chose a semi-gloss as a desired finish, and it was just painted this weekend, then let it set a few days before deciding it's too glossy. Semi-gloss finishes will "tone down" several degrees by the time it's done curing - And once you've got all your furniture moved back in and the window coverings hung, it may be just the finish you thought you were getting.
Unfortunately, if it's still too shiny even then, refer back to JSheridan's post...
ric knows paint is offline   Reply With Quote
Old 11-28-2011, 07:11 PM   #4
paper hanger and painter
chrisn's Avatar
Rewards Points: 232
Why did you paint the walls semi gloss to begin with?
Inquiring minds want to know
Old 11-28-2011, 11:43 PM   #5
Gymschu's Avatar
Rewards Points: 486
Chris, I'm with you......I can't recall the last time I painted walls with Semi-gloss. I rarely even use SG in bathrooms anymore. Unless you have outstanding drywall work, those imperfections are gonna flash through. But, to each his own.......and, maybe they were "sold" on the SG from a Behr salesman at Home Depot.
Old 11-29-2011, 01:43 AM   #6
Old 11-29-2011, 05:03 PM   #7
Too Short? Cut it Again!
Remember latex semi takes 30 days to cure to its sheen.
can you paint flat paint over semi gloss Keg General DIY Discussions 27 10-29-2011 05:59 PM
semi gloss not covering laura1 Painting 9 03-07-2011 11:41 AM
Semi Gloss Or Satin In Old House NewEnglandYank Painting 14 01-21-2011 02:37 PM
Semi gloss on Semi gloss mattpricemn Painting 6 08-25-2008 08:18 PM
Cabinet Painting: Gloss vs. Semi Gloss digexpressions Painting 1 12-29-2007 04:47 PM
