Old 08-24-2008, 05:18 PM   #1
Default Semi gloss on Semi gloss
I had a renter put royal blue semi gloss paint on the white semi gloss walls. I have to assume they didn't rough up the walls. The royal blue paint is rubbery and loose towards the bottom and I can pick at it to get off. But as I "peel" the paint upwards the royal blue paint starts to shred into smaller and smaller strips. It seems to adhear to the walls better towards the top.
I tried sanding the royal blue paint, but it gums up the different grit sandpaper and I've found this is not going to work.
I've been picking at it, but it is a never ending battle. The small strips of paint come to a point and I have to pick at it again. This is not going well. I am very frustrated
Any help is appreciated.
mattpricemn is offline   Reply With Quote
Old 08-24-2008, 07:33 PM   #2
Tired, Cold, and Damp
slickshift's Avatar
Wow...even w/o sanding (prep) it shouldn't do that
Did they use a super-cheap paint, or was the white paint oil-based?
slickshift is offline   Reply With Quote
Old 08-24-2008, 08:48 PM   #3
Old fart still learning!
slickshift,
Way out on a limb here but do you think a water-based stripper would be overkill here?
If it's worth doing, it's worth doing right. If you wouldn't put your name on it, it ain't done right!
downunder is offline   Reply With Quote
Old 08-24-2008, 10:35 PM   #4
Oh, no. I wouldn't start using a stripper on the wall. You'd make the mother of all messes as it dissolved the blue paint and the white paint and whatever paint is under that yet, too.
If you can peel strips of that blue paint off, I'd try an electric leaf blower to get some air pressure under the paint. Or, even try hooking the suction hose of your vaccuum cleaner to the exhaust port and see if that helps to remove the paint. Another option would be Scotch Tape. Just stick the Scotch tape (or duct tape) to the blue paint, and pull off the Scotch or duct tape. If the blue paint isn't sticking to the white paint as well as the Scotch tape sticks to the blue paint, you should be able to pull that blue piant off with the tape.
Different kinds of paint have different properties. I'm hoping we can exploit those differences to make the blue paint easier to get off.
Take a spray bottle and get the blue paint wet. Let it stay wet for 10 or 15 minutes, and then pick at it to see if you can get it peeling off. If the blue paint is an inexpensive (PVA) latex, it will lose it's adhesion and strength when it's wet, and you will then be able to scrape it off the white paint with a paint scraper. Use one of those paint scrapers with the tungsten carbide blade because it's sharp enough for serious scraping, but it won't scrape through oil based paint or 100% Acrylic paint without you're applying enough pressure to make the paint scraper do that.
When the blue paint has been wet for a while, grab onto a single edge razor blade with a pair of needle nose style locking pliers. Use that to see if you can "shave" the blue paint off.
Is the white paint an oil based or "alkyd" paint? If so, and if push comes to shove, you should be able to dissolve the blue latex paint without hardly any damage at all to the underlying alkyd paint by using xylene, which is available at most paint stores or PRINTING supply stores. I've been told that Goo Gone or Goof Off also remove latex paint from oil based paint, but I've never tried either of them for that application.
If the underlying white paint is oil based, and the razor scraper seems to work OK, then do both; scrape most of the blue paint off when it's wet, and then remove the residual blue paint with xylene.
Basically, you can remove latex paint from oil based paint using xylene, and you can remove vinyl acrylic latex paints from 100% Acrylic latex paints by getting the vinyl acrylic wet (so that it softens and loses it's adhesion) and scraping it off with a paint scraper.
PS: I would also try a leaf blower. If you can peel that blue paint off, but it shreads, why not get the paint started and get some air pressure under the paint to lift it off?
Nestor_Kelebay is offline   Reply With Quote
Old 08-24-2008, 10:42 PM   #5
slickshift's Avatar
Originally Posted by downunder View Post
slickshift,
I wouldn't consider that w/o more information
Generally I wouldn't consider using a stripper on a wall regardless
It's usually one of those "Seemed Like A Good Idea At The Time" deals
They rarely end up well
There are almost always better choices
...not necessarily ones you wanted to hear, like scrape and sand, but often they are better...on many levels
Old 08-25-2008, 11:19 AM   #6
That's why I was wondering about a different approach. Personally, I would go with the sanding. Not sure why the sandpaper is gumming up; maybe using the wrong kind?
Old 08-25-2008, 09:18 PM   #7
slickshift's Avatar
Some latex paints will gum up like that
More On This Topic
Newspaper Snakes: Materials
Newspaper Snakes: Materials by Expert Village
The materials needed for this project are pretty much things that you would find at home. We are going to use newspaper, it can be any size. I do recommend that it's the black and white, not a heavy heavy thickness but something that is easily folded and... Read More »
Hello, my name is Acton Seibel and on behalf of Expert Village.com we are going to talk about how to clean the underside of your lawn mower deck. You are going to need a couple of things. One is a scraper. I am using a regular old paint scraper but any... Read More »
Recycle and reuse is an often-heard theme. Why not use a canvas blind as your new canvas for painting? If the idea sounds strange, remember that artists such as Picasso have reused canvases to create new works of art. Before taking paintbrush to canvas... Read More »
Hello! My name is Grady Johnson and I'm a professional painter, and today I represent expertvillage.com. Now we're going to talk a little bit about the materials we're going to need to paint the exterior eaves on our house. Now, whenever you're painting... Read More »
This is Kevin with Expert Village one day bathroom makeover. This particular paint job we let it dry for approximately a hour and 45 minutes to 2 hours before peeling off the paint the tape excuse me that boarder the paint job. Special type of blue tape... Read More »
Semi gloss on Semi gloss mattpricemn Plumbing 1 08-24-2008 05:19 PM
Removal of peeling semi gloss paint from ceiling L Lacey Painting 2 08-15-2008 06:15 PM
painting trim with semi gloss paint sninny Painting 6 05-27-2008 09:24 AM
semi gloss sheen problems Pawl Painting 5 03-16-2008 12:29 AM
Cabinet Painting: Gloss vs. Semi Gloss digexpressions Painting 1 12-29-2007 05:47 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
