Semi Gloss Or Satin In Old House - Painting - DIY Chatroom Home Improvement Forum
Old 01-19-2011, 06:26 AM   #1
We have recently purchased a house that was built in 1889. All the walls will need to be painted. My wife prefers semi gloss paint because of the shine and it being easier to clean. Friends have told me that semi gloss paint embellishes all the imperfections and the glare is bad. To restrict it to the bathroom and kitchen only. I was told to go with satin.
Any thoughts?
NewEnglandYank is offline   Reply With Quote
Old 01-19-2011, 08:40 AM   #2
Rewards Points: 150
If it were me I would use satin/egg shell in the kitchen and bath and go flat everywhere else. I played around with satin and egg shell and to me they all looked semi gloss and semi gloss looked like gloss I never liked any of it and am repainting it all now
STL B. is offline   Reply With Quote
Old 01-19-2011, 09:11 AM   #3
Problem is my wife hates flat paint. Too dull and hard to clean. This is why I asked about satin for rooms other than bathroom and kitchen. Semi gloss in those 2 rooms are supposed to be good as a vapor barrier.
Old 01-19-2011, 09:25 AM   #4
Rewards Points: 150
Well satin or eggshell finishes dont hide anything so hopefully your 120yr old walls look better than my 100yr old walls. Besides how often does your wife wash the walls? Buy a scrubable flat?
Old 01-19-2011, 09:29 AM   #5
I think I'll go with satin, flat is unappealing.
Old 01-19-2011, 07:11 PM   #6
A lot of people use semi gloss in the bathrooms, utilities and kitchen. Its all personal preference. It also depends on the quality of the paint you use. If you go with a satin on the other walls. I wouldn't go with a cheap construction grade satin. I would go with a high quality satin or you won't be able to wash it any way. A low gade eggshell is about the same as a high grade satin, for sheen.
Go with a quality paint, not a cheap chain store paint.
You might want to consider, doing a little touch up with caulking or drywall mud before you paint.
redmanblackdog is offline   Reply With Quote
Old 01-20-2011, 04:04 AM   #7
Thanks for your reply/advice. I'll be doing a lot of touch-ups and caulking on these 100 year old walls. Wall paper stripping too.
Old 01-20-2011, 05:10 AM   #8
paper hanger and painter
chrisn's Avatar
Rewards Points: 396
[quote=STL B.;573639]If it were me I would use satin/egg shell in the kitchen and bath and go flat everywhere else. I played around with satin and egg shell and to me they all looked semi gloss and semi gloss looked like gloss I never liked any of it and am repainting it all now[/quote]
I would agree, besides any QUALITY flat paint is washable.
chrisn is online now   Reply With Quote
Old 01-20-2011, 05:18 AM   #9
Using dull flat pain in every room except bath and kitchen isn't a option if the wife hates flat paint..lol
Old 01-20-2011, 08:02 AM   #10
A Little Of Everything
Rewards Points: 1,364
Any thoughts?
I would do exactly as was recommended to you. Semi-gloss in the kitchen & bathroom, and satin everywhere else. That is exactly what we've done in our house, and the rentals. We're very happy with it all.
But you're not talking about my house, and it's not my wife who thinks differently.
From a "hide or show" perspective, the higher the gloss the more it'll show imperfections. Not a huge difference, because you can see them all if you're looking. But if it's a smooth shiny wall, any little crack or dip is more noticeable.
DrHicks is offline   Reply With Quote
Old 01-20-2011, 09:26 AM   #11
Thanks for all the advice.
Old 01-20-2011, 01:50 PM   #12
firehawkmph's Avatar
Rewards Points: 1,884
NE Yank,
one more .02. Check out Sherwin Williams low sheen eggshell. Looks almost flat, washes up nice. I used to use their eggshell all the time and then they came out with the low sheen eggshell. If you decide to get it, ask for it in their promar 200 line. The promar line is the contractor line and 200 is their best in that line.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Old 01-20-2011, 01:55 PM   #13
Jack of all - master none
hyunelan2's Avatar
Rewards Points: 692
I can't stand when an entire house is semi-gloss. Everything being shiny makes it look cheap, IMO.
My last house, we used a lot of flat. Never again. Now, I use eggshell in most areas, satin in kitchen/bath, and semi-gloss only goes on trim.
hyunelan2 is offline   Reply With Quote
Old 01-20-2011, 02:04 PM   #14
That's pretty much what my wife & I do.
We've also noticed that the sheen of satin, semi-gloss, and eggshell can vary quite a bit from one manufacturer to another.
Old 01-21-2011, 01:37 PM   #15
I just used Benjamin Moore Regal with the 'pearl' finish in my kitchen. I think it has just enough sheen, especially when the sun is shinning, but it is not 'shiny'. I have used a wet sponge to clean some smudges with no problems. I really like it!
sychopants is offline   Reply With Quote
Connecting main house to guest house... hlavine Building & Construction 31 03-28-2012 09:04 AM
Trane XR12 1.5 ton-Too small for my house? Badfish740 HVAC 7 09-23-2009 05:48 AM
I have Central Heating & Air, but house won't cool down..HELP!! exiledone1 HVAC 13 07-10-2009 10:09 PM
Satin, Semi-Gloss or Gloss PearlWhiteGT Painting 2 05-05-2009 09:48 AM
semi gloss enamel umcgirl Painting 3 03-12-2009 09:09 AM
