Semi Gloss Over Flat - Exterior - Painting - DIY Chatroom Home Improvement Forum
Old 06-29-2013, 05:01 PM   #1
Renovating My Land Yacht
Rewards Points: 616
semi gloss over flat - exterior
My assumption is that if the two paints are the exact same color and brand and just a different finish then I can put semi over the flat correct?
This is in reference to the exterior doors I had to work on that were starting to show signs of rust.
Cleaned, sanded and primed em yadda yadda but instead of leaving them primed and looking like crap I put on a coat of exterior that I was using for the trim on a few spots outside. Color looks great and finish looked great.....when it was wet. Dry....not so much except at a distance.
I know I should have done the semi straight up but was hoping to be able to cheat for a few months while getting other more important stuff done but I cannot stand how it looks. The doors and paint job are fine just hating the flat finish.
Can I throw the other stuff straight over the top or are you going to send me to purgatory and make me prime again
Robyn
forcedreno2012 is offline   Reply With Quote
Old 06-29-2013, 05:27 PM   #2
Too Short? Cut it Again!
If the flat finish was oil based and you put exterior latex over it without primer you could experience some problems. Otherwise your second coat should bring the sheen to what you expect.
You did prep the surface right? If it was chalking and you did not remedy that you could also have problems.
Old 06-29-2013, 05:28 PM   #3
paper hanger and painter
chrisn's Avatar
Rewards Points: 228
Paint away.
Might I ask why or what you were painting flat on an exterior?
Old 06-30-2013, 04:37 PM   #4
Painting Contractor CT
Rewards Points: 77
Post
Better if you had mixed them together, then painted.
KD PAINTING is offline   Reply With Quote
Old 06-30-2013, 04:55 PM   #5
Rewards Points: 5,974
I don't but I know some guys that use flat as primer.
Old 06-30-2013, 06:09 PM   #6
chrisn's Avatar
Rewards Points: 228
huh?
Old 06-30-2013, 08:33 PM   #7
Rewards Points: 616
Thanks all didn't think it would be an issue but wanted to check. I have only put semi over primer over flat and wasn't sure if it need to be primed again.
SD = yup scrubbed, sanded and primed with metal primer then the flat. The rust issue was from a small spot where something banged the door floating in the flood and was starting to rust because of the crap in the water.
Chris...was cheating temporarily. Didn't want to leave them just primed why we were finishing other stuff up and thought what the heck at least it will look somewhat finished till I get to it...it does but does not look right so will be putting the semi on. Looks rather hackish
Robyn
Old 07-02-2013, 12:18 PM   #8
Rewards Points: 4,792
No of course you don't have to prime over flat paint. If you did, you'd have to prime between every coat of paint you put on anything, which is ridiculous and leads to an infinite series of paint coatings if you think about it.
jeffnc is offline   Reply With Quote
Satin or Flat for Exterior Paint Sheen?? Which is most durable/protective? DamonBoost Painting 12 06-17-2015 08:28 AM
valspar semi gloss "paint" vs "enamel" ? pman6 Painting 15 04-07-2013 09:40 PM
How to protect semi gloss latex paint on wall clorenc Painting 1 04-28-2012 03:09 AM
painting over semi gloss paint ckr31 Painting 3 10-10-2010 09:43 AM
Removal of peeling semi gloss paint from ceiling L Lacey Painting 2 08-15-2008 05:15 PM
