Semi-gloss Mistake? - Painting - DIY Chatroom Home Improvement Forum
Old 03-10-2009, 09:50 AM   #1
Semi-gloss mistake?
We had some book shelves that were painted with semi-gloss about 8 years ago. We repainted them with semi-gloss without scuffing in between. After 48 hours they are still tacky to touch. My DH says it is because we are having high humidity right now (raining) and that it will just take longer to cure? Is this true and if not how do I save this paint job? Its a LOT of book shelves! Ugh.
Paintknot is offline   Reply With Quote
Old 03-10-2009, 11:16 AM   #2
Yes. High humidity will cause it to dry slow and cure longer.
waynech is offline   Reply With Quote
Old 03-10-2009, 11:49 AM   #3
Rewards Points: 506
Yes. For bookshelves, you should wait at least two weeks (if not longer) before loading them up. This especially applies if you used wall paint instead of Waterbourne enamel.
SirWired
sirwired is offline   Reply With Quote
Old 03-10-2009, 12:05 PM   #4
Rewards Points: 324
What is Waterbourne enamel and why is it a better choice for painting bookshelves?
gma2rjc is offline   Reply With Quote
Old 03-10-2009, 12:13 PM   #5
Rewards Points: 506
Waterbourne enamel (two common examples are SW ProClassic and BM Impervo) dries to an extremely hard film after it cures. And this film is very resistant to "blocking", which is the tendency of paint to stick to something placed on top of it.
SirWired
Old 03-10-2009, 12:37 PM   #6
Rewards Points: 324
Okay, thank you.
Old 03-10-2009, 07:57 PM   #7
Thumbs up
Thanks!
Thanks for your information. So even though I didn't scuff the semi-gloss surface before applying semi-gloss paint it may cure in about 2 weeks? You have given me very good news. I will remember what you said about Waterbourne paint and look into that next project. :-)
Old 03-11-2009, 07:48 AM   #8
The rainy season is making it humid and tacky once its over its going to dry up and look okay.
Dana
http://www.ninaathome.com/
Dana11 is offline   Reply With Quote
Old 03-11-2009, 08:02 AM   #9
paper hanger and painter
chrisn's Avatar
Rewards Points: 228
Put a fan or two in the room to help it dry.
Old 03-11-2009, 05:44 PM   #10
Tired, Cold, and Damp
slickshift's Avatar
Cheap paints (rather than a quality enamel for shelves), can have "blocking", or "stickiness when objects that are placed on them are lifted up" forever
It could be your product
...also deep colors can have loads of slow drying solvent-based tints in them that affect the drying/cure time
It could be your color
....humidity and cold can also greatly increase dry/cure times
It could be your environment
Tacky to the touch after one day, I'd say it's color or environment
Start that fan, wait for a few drier (or warmer) days, and give it a few days (maybe a week depending), before making any rash (more work) decisions
Tacky when objects are placed on it (blocking) after curing (a few weeks depending), I'd say it was product
slickshift is offline   Reply With Quote
Old 03-11-2009, 06:17 PM   #11
Slickshift
Hi, I'm a Ma. painter working on a house in Osterville right now. It's been slow but we're surviving. How goes it with you?
Old 03-11-2009, 10:00 PM   #12
Question
Thanks again!
Thank you all for your input. You reassured me quite a bit. And as the days go by the shelves are curing and getting dryer. I will take the advice of waiting a few weeks for them to cure before I attempt to put anything on them. But I have learned more than one lesson. Rainy weather is not a time to paint and to sand or etch glossy finishes before reapplying paint.
I used Behr paint from Home Depot. I was assured that this is a good quality paint. Is that not true?
Old 03-11-2009, 10:18 PM   #13
Rewards Points: 324
There is a thread on this forum where some of the professional painters are talking about the paint brands. Behr paint didn't seem like it was real popular with them. In 2005 I built and painted some shelves I made for my rubber stamps. Almost 4 years later, I still have to tug just a little bit to lift some of them up. They're not very heavy, but they still stick just a little bit if they sit for more than a couple weeks. Luckily, they don't pull the paint off or anything like that. I bought some Sherwin Williams waterborn enamel to paint some baseboards, so I'm thinking about re-painting the shelves with that.
Old 03-12-2009, 06:27 AM   #14
chrisn's Avatar
Rewards Points: 228
Who were you assured by?? the guy at HD?
Is that not true?
"better to leave the walls bare than put Behr on the walls"
painting trim with semi gloss paint sninny Painting 10 09-21-2012 05:33 AM
Semi gloss on Semi gloss mattpricemn Painting 6 08-25-2008 08:18 PM
Semi gloss on Semi gloss mattpricemn Plumbing 1 08-24-2008 04:19 PM
semi gloss sheen problems Pawl Painting 5 03-15-2008 11:29 PM
Cabinet Painting: Gloss vs. Semi Gloss digexpressions Painting 1 12-29-2007 04:47 PM
