Old 10-15-2008, 04:54 PM   #16
semi gloss enamel vs eggshell enamel
I have been selling paint since 1994 and the ? about latex or enamel is always brought up. Enamel is a misused word. Enamel is the level of gloss in your paint. Most people think "oil or "latex". Oil base paint is called a "alkyd enamel", you clean up with mineral spirits aka paint thinner. Latex or acrylic is just that, a latex or acrylic enamel you clean up with soap and water. I hope this helps. Now for your garage, a satin or semi gloss "latex or acrylic enamel" will be fine. It is a harder finish than you standard flat or eggshell finish. And since no garage is dust proof, it will be easier to dust down your walls. Good luck and e-mail me if you have anymore questions.. gainesville@colorwheel.com Duane, Color Wheel Paints and Coatings
Duane Foster is offline   Reply With Quote
Old 10-16-2008, 12:46 AM   #17
Originally Posted by NoExperience View Post
Nestor who carries General Paint?
I did a search trying to find out who carries it and I came up empty.
Sorry, I missed the question first time 'round...
General Paint is part of the Comex Group, which is a group of paint companies that distribute the paints made by Comex, which is the largest paint manufacturer in Mexico. The companies in the group are:
General Paint
Color Wheel
Frazee
Parker Paint, and
Kwal
http://www.hoovers.com/comex-group/-...-profile.xhtml
If you can find any of those paint companies in your area, they should sell EnviroGard, perhaps under a different name. Just ask about their "waterborne acrylics" and you should get the same stuff as EnviroGard.
I wish I knew how the stuff worked, but it does form a very hard and durable film, and the fact sheet linked to earlier does say it's an acrylic binder. It also says that it takes 28 days to fully cure, so it crosslinks. Beyond that, I don't know anything about the stuff, except that I've used it and it is a very durable coating, equal to oil based coatings in my view.
I used it about 20 years ago to paint the back stairway hand rail in my building, and that paint has stood up well for 20 years and counting. If you want a super durable paint with the advantage of water clean-up, EnviroGard (or competitor's equivalent) is certainly one way to go.
Just wish I knew what exactly was in it, and how it formed such a hard durable film with an acrylic binder.
Nestor_Kelebay is offline   Reply With Quote
Old 02-07-2009, 10:42 PM   #18
I have found Behr paint to stay tacky for a long time. Sherwin Williams 200 eg-shel is pretty easy to work with but ask them to give you the contractors price it is about 19.00 a gallon
DGideon is offline   Reply With Quote
Old 03-05-2009, 05:57 AM   #19
i prefer using semi gloss paints. easy maintainance paint easy to clean up too
Dana11 is offline   Reply With Quote
More On This Topic
Hi I'm Betty Ingham on behalf of Expert Village. Cut out something for a Christmas ornament and you may want to put something in for a whole if they wanted to you know hang it on a Christmas tree later on. And they can either paint it with just acrylics... Read More »
I hope you guys had fun and I hope you are off to a great start experimenting with acrylic paints. There is so much to do it's really endless. So if you decide that you have come up with a painting and you would like to protect it it's very durable... Read More »
Artists use many different objects as canvases, everything from pieces of tin to rocks and even wood. Try something even more unusual by varying your brushes and painting with acrylics on feathers. Read More »
On behalf of Expert Village my name is Carolyn Travisano and I am here to tell you about painting on feathers. Okay so let's start with going through my paints and brushes, different things that I use. I mentioned earlier for the quill of the pen I use... Read More »
Artists use many different objects on which to do their work. For the most part one would use a canvas, but some people get very creative and use everything from pieces of tin to rocks and even wood. Try something even more unusual by painting with... Read More »
Semi gloss on Semi gloss mattpricemn Painting 6 08-25-2008 08:18 PM
Semi gloss on Semi gloss mattpricemn Plumbing 1 08-24-2008 04:19 PM
painting trim with semi gloss paint sninny Painting 6 05-27-2008 08:24 AM
semi gloss sheen problems Pawl Painting 5 03-15-2008 11:29 PM
Cabinet Painting: Gloss vs. Semi Gloss digexpressions Painting 1 12-29-2007 04:47 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
