Semi Emergency - Painting - DIY Chatroom Home Improvement Forum
Old 07-09-2009, 05:49 PM   #1
Semi Emergency
Used alkyd paint on an exterior door. It's very humid today and the paint is not dry enough yet to close the door. How can I keep it from sticking to the weatherstripping. Would a coating of baby oil work? My friend's husband will be home soon and it's about 103. The AC is running continuously and it's 82 in the house. Help!
Sasha2000 is offline   Reply With Quote
Old 07-09-2009, 06:45 PM   #2
Put a plastic sheet up over the doorway & leave the door open to dry
That's what you should have done in the 1st place
Painting on a humid day not a good idea if you need something to dry quick
Old 07-09-2009, 06:51 PM   #3
Pull the weather strip out.
waynech is offline   Reply With Quote
Old 07-09-2009, 09:47 PM   #4
Matthewt1970's Avatar
Rewards Points: 1,098
Point a fan at it.
Old 07-11-2009, 06:30 PM   #5
All of the above. Next time, you could also try a bit of japan dryer in the paint, but check with the vendor first, as paint chem is a lot more complex than it used to be.
99BN99 is offline   Reply With Quote
Aux and Emergency CPH settings indvid HVAC 2 03-02-2009 03:31 PM
Help..Emergency Heat Running All the Time KatieB HVAC 4 02-25-2009 04:55 AM
A Mold Remediation Emergency White Elk General DIY Discussions 29 10-04-2008 09:01 AM
Semi gloss on Semi gloss mattpricemn Painting 6 08-25-2008 07:18 PM
