Self-priming Ceiling Paint? - Painting - DIY Chatroom Home Improvement Forum
Old 11-19-2009, 05:50 AM   #1
Self-priming ceiling paint?
I just got finished building my new garage (something I have been waiting for for a long time). I want to paint the drywall ceiling and in the essence of time, would like to use a self-priming paint. I noticed Zinsser Perma-White eggshell and Ben Moore Muresco claim to be self-priming on new drywall. Has anyone had success using 2 coats of paint only on new drywall? In my home I would absolutely prime and 2 coats of paint but I'm not as picky for a garage ceiling.
slickracer is offline   Reply With Quote
Old 11-19-2009, 09:09 AM   #2
Too Short? Cut it Again!
Self priming paint and primer combos come in special, dark black, cans. You can only buy the ones that really work after or around midnight. In dark alleys. Send me a private message and I will make arrangements. Or...
Prime it!
The Following User Says Thank You to user1007 For This Useful Post:
tamirh (07-07-2010)
Old 11-19-2009, 11:44 AM   #3
Very helpful answer, I can't thank you enough.
Old 11-19-2009, 02:37 PM   #4
ccarlisle's Avatar
I think that - especially on drywall - you'd want a primer to fill in the miicroscopic voids in the paper; now primers are loaded not with ultrafine titanium dioxide like finish coat paints, but with cheap talc and clays that are there for that reason only. That's why apart form the cheap PVA resin, that primers are cheap.
Now the so-called one coat primer+paint products seem to be a compromise on both fronts; they're probably good primers but they'd make lousy finish coat products just because of the way they were formulated.
“The average American woman is about 25 pounds heavier than she was in 1960...Recognizing obesity as a disease will help change the way the medical community tackles this complex issue that affects approximately 1 in 3 Americans,”
ccarlisle is offline   Reply With Quote
Old 11-19-2009, 06:01 PM   #5
paper hanger and painter
chrisn's Avatar
Rewards Points: 394
For your ceiling ,2 coats of Ben Moore Muresco will do the job.
Zinsser Bathroom Paint canuckjack Painting 7 08-27-2012 08:00 AM
peeling paint on old plaster ceiling zymurgea Painting 7 09-12-2009 04:42 AM
Paint riddle... Please help me fix this? techprincesse Painting 8 08-24-2009 10:00 AM
I used ceiling paint instead of primer by mistake SOCCERDAD Painting 4 03-25-2009 05:36 AM
Priming "builders grade" paint before painting Plasmech Painting 10 03-30-2008 01:37 PM
