Second Coat Of Primer On New Cabinet Doors? - Painting - DIY Chatroom Home Improvement Forum
Old 09-03-2013, 03:18 PM   #1
Rewards Points: 54
Second coat of primer on new cabinet doors?
I'm in the midst of painting my kitchen cabinets. New doors are paint grade maple. The local paint store recomended 2 coats of oil primer, sanding between each. Is there a benefit to the second coat, or am I just adding work to this project? I'm almost done with the first coat on all of the doors.
wetech is offline   Reply With Quote
Old 09-03-2013, 03:38 PM   #2
Gymschu's Avatar
Rewards Points: 668
I'm entering my 35th year as a painter and I have never, ever applied two coats of primer to anything.......So, no, you DO NOT need a second coat of primer.
Old 09-03-2013, 04:16 PM   #3
Jmayspaint's Avatar
Rewards Points: 534
The only reason I could see for applying a second coat of primer is to give you a thicker sanding base. Or maybe to help keep knots from bleeding.
People on here talk about double priming a lot. That's probably because of applying thin coats.
One good full coat of primer should be enough, but if it seems thin to you it certainly doesn't hurt to do it twice.
Jmayspaint is offline   Reply With Quote
The Following User Says Thank You to Jmayspaint For This Useful Post:
Gymschu (09-03-2013)
Old 09-03-2013, 04:38 PM   #4
Rewards Points: 4,796
Another reason for priming twice would be to block serious stains that didn't quite get blocked in the first coat. You see this sometimes in manufacturer's instructions. IMO, usually that means you weren't using quite the right primer to begin with. For example, traditionally water based stain blockers don't block water stains very well. Instead of trying 2 or 3 coats of a water based stain blocker, use 1 coat of an oil based stain blocker (or BIN, which is alcohol based.)
jeffnc is offline   Reply With Quote
The Following User Says Thank You to jeffnc For This Useful Post:
Old 09-03-2013, 04:45 PM   #5
K&B Designer
Live_Oak's Avatar
Not to be insulting, but it could be because it's a DIY job, and that's not often noted for the smoothest paint job!
And some woods will get a slight rise to the grain if you use a water based primer. (Which I wouldn't recommend.)
Personally, one good coat of BIN is all that I've ever needed for a paint project over raw wood. But, I've been painting projects for a looooong time.
Live_Oak is offline   Reply With Quote
The Following User Says Thank You to Live_Oak For This Useful Post:
Old 09-03-2013, 06:27 PM   #6
Rewards Points: 5,974
Stain grade maple 1 coat should be plenty some other woods I could see 2 coats but not maple.
The Following User Says Thank You to ToolSeeker For This Useful Post:
oh'mike (09-03-2013)
Old 09-03-2013, 09:32 PM   #7
Rewards Points: 54
my initial plan was to hit it with a coat of BIN first. The manager at the paint store said that was the wrong primer for unfinished maple, and suggested a BM oil primer.
Old 09-03-2013, 09:32 PM   #8
Rewards Points: 54
this is paint grade. There's some dark sections, no knots though.
Old 09-03-2013, 09:35 PM   #9
Sorry I meant paint grade.
Old 09-03-2013, 09:43 PM   #10
Rewards Points: 54
ok thanks. I thought it was overkill
Old 09-03-2013, 09:46 PM   #11
Matthewt1970's Avatar
Rewards Points: 1,098
I can see where he was coming from. Maple is an extremely hard wood so I can see BIN not penetrating as well as an oil based primer as it dries very quick.
Latex Primer: Good for Drywall, that's about it.
Behr Paint: The plastic buckets are good, that's about it.
2 coats stain or 1 coat primer & 1 coat paint? bhtko Painting 25 08-11-2012 06:43 PM
Need advice using Insl-x Cabinet Coat ladydub Painting 13 06-29-2012 03:22 AM
Painting grooves in kitchen cabinet doors. jcraw84263 Painting 5 11-10-2011 12:05 PM
Is 1 coat of primer typical or two? abefroman Painting 8 05-12-2011 12:55 PM
pocket hole joinery for cabinet doors? Jeremy Hillary Boob, PhD Carpentry 4 03-09-2009 05:26 PM
