Second Coat Of Paint? - Painting - DIY Chatroom Home Improvement Forum
Old 08-17-2013, 11:08 PM   #1
Rewards Points: 12
Second coat of paint?
So I just finished the first coat on the exterior of my house (T1-11 siding) using Behr's Premium Plus Ultra. I had first spot primed bare wood and rough spots with Behr Premium Plus Multi-Surface Primer and Sealer. I didn't realize that the Premium Plus Ultra was a primer as well. Oops. Oh, well. I'm keeping the house and want a good, long-lasting paint job, so I'm assuming I should do a second coat, . . . or? Is two coats standard? If so, I'll just use the Premium Plus (without the primer) for the second coat. I'm using a roller and chasing with a brush. Thanks for your replies.
psychopengy is offline   Reply With Quote
Old 08-18-2013, 01:03 AM   #2
paper hanger and painter
chrisn's Avatar
Rewards Points: 504
Yes a second coat because there is NO primer in the paint
Old 08-18-2013, 07:42 AM   #3
cdaniels's Avatar
^^^ this and yes 2 coats always.
Charlie Daniels painting and repair
cdaniels is offline   Reply With Quote
Old 08-18-2013, 10:58 AM   #4
Rewards Points: 4,796
A specialty primer used before the paint is going to be at least as good as a paint-and-primer-in-one product. Over bare wood I would have chosen the specialty primer first anyway. A second coat is only going to help. Have you considered their new Marquee line of paint? If you're looking for the best quality and longest lasting, that is the way to go. Of course another coat of their standard paint will be fine too.
jeffnc is offline   Reply With Quote
Old 08-18-2013, 02:26 PM   #5
Rewards Points: 5,994
When dealing with T-111 if you have any of the sealer left I use it along the bottom and top edge of your boards this is where T-111 usually starts to rot because water can wick up into unsealed edges. And be very liberal with it.
ToolSeeker is online now   Reply With Quote
The Following User Says Thank You to ToolSeeker For This Useful Post:
Pro Painter (08-18-2013)
valspar paint, not as adverised? or just me? Lethrneck4 Painting 33 04-26-2013 08:01 AM
Flat over Semi-Gloss dankreboot Painting 21 02-24-2013 07:46 PM
Dark over light...Do I need tinted primer? melissaandkris Painting 17 09-09-2011 10:43 AM
Flaking lead paint on plaster - skim coat? sabernar Remodeling 1 05-05-2009 06:49 AM
Paint will not stick in Bathroom! SGTHetland Painting 9 08-17-2008 11:04 PM
