Second Coat? First Was Sikkens Cetol Srd - Painting - DIY Chatroom Home Improvement Forum
Old 10-04-2010, 03:14 PM   #1
second coat? first was sikkens cetol srd
after one coat of sikkens cetol srd i had a flat finish and the color i desired.
i need to apply something now, after a few years, to preserve the wood siding. the sikkens second coat makes the wood a shinny finish and brings out a redish color, which i do not want. any suggestions? Lindseed oil leaves some wet looking residue - not great.
jimcarpenter is offline   Reply With Quote
Old 10-04-2010, 08:56 PM   #2
Rewards Points: 150
Screw Sikkens, Use Cabot's Austrailian timeber oil (see if you can get the 550 voc) apply one coat of that. Only put on as much as the wood will take in.
hammerheart14 is offline   Reply With Quote
Old 10-05-2010, 05:59 AM   #3
Doer of Many Things
poppameth's Avatar
Rewards Points: 576
SRD is a one coat product. It's a sacrificial coating, designed to weather away as it protects your wood. You do NOT apply a topcoat of the satin product to it. That is a different product line. If you wanted that look and a film forming layer of protection you should have done 2 coats of Log and Siding.
poppameth is offline   Reply With Quote
Has anyone every used the sikkens cetol products? choppermrt General DIY Discussions 3 06-11-2010 05:43 PM
Primer - even coat needed? DaveSD Painting 7 05-10-2010 03:40 PM
partial second coat - did I mess up? matt_ Painting 5 09-22-2009 06:17 PM
Can you put brown coat on if it's going to rain? Not Sure Building & Construction 3 03-23-2009 06:57 AM
stucco finish coat efaxsteph Building & Construction 2 03-24-2008 06:23 PM
