Old 06-27-2011, 09:54 PM   #1
Sealing tabletop
Hello all,
I'm new to the forum, and it looks like a great, active group here. I will be moving to a new place this weekend (starting over with not much money to spend). Found a used dinette set with chairs in really good shape, but the tabletop was pretty rough. It's off-white melamine. I've primed with two coats of oil-based stain-covering primer, then did two coats of low-VOC paint (all purchased from our local re-use center because it was the cheapest place in town). I used a new 1/4" roller for the paint, but it's so thick that I have a raised texture (actually would like it if I was painting walls, but not for a table, LOL). I know I'll sand it down before sealing, but it makes me worried about the sealer coat. I plan on using water-based poly, but how should I apply it? I'm painting outside, with low humidity and temps in the upper 70s-low 80s. Paint dries pretty fast. I don't have a sprayer, and need to spend as little as possible. Thanks in advance!
ETA: This may sound weird, but would it help if I could pour the poly on, and use brushes/sponges as little as possible?
divadee is offline   Reply With Quote
Old 06-28-2011, 10:05 AM   #2
sdsester's Avatar
Sealing tabletop
First remember that latex products take 30 days to cure even though they dry to the touch much more quickly. Do not race putting on a sealer coat or you could end up with a mess.
Now, you are planning a clear sealer? I would use something like a 3/8 to 1/2 roller. 1/4 is too thin.
sdsester is offline   Reply With Quote
Old 06-28-2011, 11:01 AM   #3
Sealing tabletop
use a foam roller.. i use them on railings they yeild great near - flat results with a good leveling paint.. dunno about a sealer thou.. test it out.. they are cheap
jarheadoo7 is offline   Reply With Quote
Air sealing attic mmastran Insulation 11 05-25-2011 08:31 AM
Does anybody know how to get the top off a Rheem Imperial Electric Tabletop? MrBang Plumbing 1 02-20-2011 07:46 PM
sealing compound?! mmhendrie Electrical 1 07-18-2010 07:51 PM
Sealing new boxes on an exterior wall Mthrboard Electrical 1 08-16-2009 09:05 PM
Sealing windows with vinyl siding bighoneydolist Building & Construction 8 03-08-2009 07:36 PM
