Old 10-23-2012, 12:57 AM   #1
Sealing pine knots before painting
I am going to be painting some exterior knotty pine siding and want to seal the knots so they do not bleed through. I am going to use a shellac based primer to spot prime the knots, then a coat of latex stain blocker primer on the entire surface before my finish coat. Will this do the trick? Any other sugestions for sealing the knots?
Hardwood Head is offline   Reply With Quote
Old 10-23-2012, 01:11 AM   #2
If you just used shellic on the knots then the shellic based primer you would save a step.
Old 10-23-2012, 04:40 AM   #3
paper hanger and painter
chrisn's Avatar
Good to go, despite what Mr, Joe says.
Bin is not an exterior primer, it IS OK to spot prime with
The Following 2 Users Say Thank You to chrisn For This Useful Post:
sdsester (10-23-2012), ToolSeeker (10-23-2012)
Old 10-26-2012, 08:40 PM   #4
Pro
XIM 400 for exterior
smalpierre is offline   Reply With Quote
Old 10-27-2012, 04:34 AM   #5
chrisn's Avatar
XIM is a fine primer but not labeled for sealing pine knots
Old 10-27-2012, 11:04 AM   #6
Matthewt1970's Avatar
Shellac is what you want for the knots but my next step would be a full coat of oil primer.
Latex Primer: Good for Drywall, that's about it.
Behr Paint: The plastic buckets are good, that's about it.
Pine knots bleeding through oil based paint Karen Wright Painting 10 07-18-2011 11:57 PM
Lots of advice needed - exterior painting. lazzlazz Painting 1 06-20-2011 08:56 PM
Painting / Sealing over bleach Crystal2 Painting 2 06-19-2011 02:42 PM
Painting pine - primer? marliz Painting 17 12-12-2010 08:37 PM
Painting Rough Pine is it possible rdalrymple Painting 7 11-24-2008 08:57 PM
