Sealing/Painting Suede Staircase - Painting - DIY Chatroom Home Improvement Forum
Old 09-25-2012, 01:53 PM   #1
I recently ripped up the old carpets on my stairs. The stairs are in pretty good condition. I was going to just re-paint them (They were painted white under the stairs.) I stumbled upon the Suede Paint. I followed the instructions and it came out pretty good. There are what seems to be a little white showing through, only showing if you stick your nose up to the steps. Do I paint a second coat the same way or just let it go?
Also should I seat the stairs with a coat/s of polyurethane? Will that ruin the look of the suede steps?
Thank you in advance.
phillysfinest4 is offline   Reply With Quote
Old 09-25-2012, 03:41 PM   #2
Rubbin walls since'79
Brushjockey's Avatar
Suede steps? On the treads?
Was it Ralphy paint?
I don't think the texture will wear well.
paint some of it on a test board and try a couple of clears over it to see what it does- how it looks..
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 09-25-2012, 04:40 PM   #3
Yeah, the upstairs get zero use now and it still is being renovated. No plans to do so for a while. Wanted something cool looking since I didn't stain them
Old 09-25-2012, 06:30 PM   #4
Too Short? Cut it Again!
And you forgot to prep them and prime them first right? Went straight to paint?You might as well put a second coat on to even out the color and sheen.
Good luck. What you don't want to do is heap layers on top at this point. You cannot fix adhesion from the top down with paint.
I don't have a good feeling about this look lasting for you without constant touch up. And yes, even a satin poly will destroy the suede look.
Old 09-25-2012, 06:48 PM   #5
I appreciate your honesty. First time home buyer so its good to learn from my mistakes. Thanks though
The CELLAR gbwillner Project Showcase 112 02-17-2012 10:00 PM
fix sag around staircase fixhouse Building & Construction 3 02-09-2012 06:16 PM
Space needed for L-shaped staircase with 2 landings redpanda Building & Construction 1 07-28-2010 06:32 PM
Staircase help please!!! sdba Carpentry 3 02-09-2010 12:58 PM
Framing for drywall under Spiral staircase clemon03 Drywall & Plaster 6 07-17-2009 03:49 PM
