Sealing New Drywall B4 Paint - Painting - DIY Chatroom Home Improvement Forum
Old 06-29-2012, 01:09 AM   #1
Sealing new Drywall b4 Paint
what does sealing do for new drywall and is this necessary? I am going to prime my new drywall and there are a bunch of primers with sealers.
aigsrone is offline   Reply With Quote
Old 06-29-2012, 01:28 AM   #2
Rewards Points: 558
The tint in the primer hides the gray colour of the drywall and preps the wall for a more durable and washable finished surface.
epson is offline   Reply With Quote
Old 07-02-2012, 01:51 PM   #3
Rewards Points: 626
What you want to do is use a high quality PVA primer the mud and tape and the paper of the drywall is porous and if you don't use a PVA primer you will use a ton of paint. because the sheetrock will soak it up. A good PVA primer will cost around 45 dollars per five gallons.
Nailbags is offline   Reply With Quote
Old 07-02-2012, 05:47 PM   #4
paper hanger and painter
chrisn's Avatar
Rewards Points: 124
name one
I will take exception to the quote in greeen. Any quality primer will seal the drywall, mud, tape etc., without using a ton of it. I prime new drywall almost every day and NEVER use PVA primer. I have found that at least in the past that it was a very inferior product. Maybe it has changed. Me, I am not going to find out.
$45 for a five says it all
Old 07-02-2012, 05:50 PM   #5
Matthewt1970's Avatar
Rewards Points: 1,098
Yep, even that is overpriced for PVA.
Latex Primer: Good for Drywall, that's about it.
Behr Paint: The plastic buckets are good, that's about it.
Old 07-02-2012, 06:44 PM   #6
Rubbin walls since'79
Brushjockey's Avatar
I just used Primecoat2 from HD ( I think it is renamed Bulls Eye for the orange box..) . 13.sumptin a gal - gives sufficient hold out for an eggshell.
And I also dont use pva. I have seen that stuff come off in sheets..
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 07-02-2012, 11:17 PM   #7
Rewards Points: 626
Gee Sherwin Williams Dry wall Primer and sealer has PVA in it.
Old 07-02-2012, 11:38 PM   #8
Perfect. I won't use that either. Theres always someone who will buy it.
Old 07-03-2012, 09:57 AM   #9
Not really the way to look at it as a LOT of paints have PVA. If you take out almost all the ingredients in paint or primer you are left with PVA (Polyvinyl Acetate). For a primer to brag about having PVA in it is like it also bragging that it has water in it.
Flat over Semi-Gloss dankreboot Painting 21 02-24-2013 08:46 PM
Ultimate choice for sealing wooden paint jobs? roasted Painting 16 01-24-2012 12:07 AM
Drywall Repair - Paint peeled off down to drywall TJoy Drywall & Plaster 5 06-24-2011 03:48 PM
Paint riddle... Please help me fix this? techprincesse Painting 8 08-24-2009 11:00 AM
