Sealing Joint Mud. - Painting - DIY Chatroom Home Improvement Forum
Old 11-13-2007, 01:36 PM   #1
Neweller
Sealing joint mud.
I have been floating complete walls with joint mud to a smooth finish and then painting them. However the current room I am working on I was meant to plaster but didn't research in time so I added the paint color directly to the mud and did 2 thin coats. It looks really good but I figure I have to seal it. Has anyone got any suggestions on products to use. Something that wont change the integral colour and will not gloss up too much. Appreciate it.
micknewell@hotmail.com is offline   Reply With Quote
Old 11-14-2007, 11:30 AM   #2
Rewards Points: 5,336
A polyurethane with whatever sheen you want. I've never heard of adding paint to compound. Can you post a photo?
Ron
Old 11-14-2007, 06:52 PM   #3
Pro Painter
Waterbased poly will remain completely clear, may have trouble finding a matte though.
joewho is offline   Reply With Quote
Old 11-15-2007, 08:22 PM   #4
General Contractor
McCloskey make a flat clear designed to Faux and other special effect finishes without adding unwanted sheen.
jensenconstruction is offline   Reply With Quote
Old 11-15-2007, 10:07 PM   #5
Paint/Faux Artisan
Da Vinci's Avatar
Clear acrylic satin works well or Zar flat polyurethane dries quick and gives a very low sheen effect.
Bay Area Faux Finishes
Da Vinci is offline   Reply With Quote
Plaster to drywall joint question. ERIK2173 Remodeling 7 05-16-2009 04:58 PM
Advicce on broken joint on wooden frame of chair markhod Carpentry 2 08-11-2007 08:48 PM
What brand of Joint Compound? mwehnes Building & Construction 6 03-26-2007 07:11 PM
expansion joint farrington135 Building & Construction 1 01-27-2006 10:02 PM
