Sealing A Chimney - Painting - DIY Chatroom Home Improvement Forum
Old 02-18-2011, 09:52 AM   #1
Sealing a chimney
I have a question on what to use to seal the outside of the chimney more for sanitary purposes? I am remodeling a house and have decided to leave two sides of the chimney open on a bathroom wall and was told to seal it with something because the bricks could hold bacteria and other things. The chimney has a flue pipe through it and out of the roof but the brick part of the chimney is under the roof line. I just want something that may give a little shine and seal it up some. Thank you
Thunder219 is offline   Reply With Quote
Old 02-20-2011, 06:06 PM   #2
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,086
Are you wanting to seal the brick?
A pic would help.
Old 02-20-2011, 06:24 PM   #3
Painting Company, NY
housepaintingny's Avatar
Rewards Points: 616
Sherwin Williams Shercret it is a waterproofing paint that will bridge hairline cracks, its breathable, comes in any color and is masonry specific. No primer is needed for this product.
housepaintingny is offline   Reply With Quote
Old 02-20-2011, 09:27 PM   #4
not a very good pic. I dont know that it needs anything I just wasnt sure on it being unsanitery next to the sink.
Old 02-21-2011, 12:31 AM   #5
Stuck in the 70's
I sure hope not!
This is a pic of our master bath. The main bathroom has even more brick. I just take a broom to the whole house every couple months.
Old 02-22-2011, 10:57 AM   #6
Thank you. I think I will just leave it for now. I thought it would look nice just to have it the way it was and hope I don't regret drywalling around it when everything is done.
Old 02-22-2011, 08:50 PM   #7
Gymschu's Avatar
Rewards Points: 934
There are many CLEAR masonry coatings on the market that could seal up the brick yet leave the look.
Sealing chimney cap? turbomangt Building & Construction 3 04-13-2010 08:46 AM
Sealing chimney chase(?) cbrc5eric Building & Construction 3 03-15-2010 09:31 AM
Chimney Damper sealing Giles General DIY Discussions 1 02-12-2010 04:04 PM
Chimney crown sealing hdhogger General DIY Discussions 1 12-10-2008 05:25 PM
Looks like leaking around the chimney - roofer says it is the chimney itself Salvatorparadise Roofing/Siding 6 03-07-2008 03:12 PM
