Sealing Bottom Of Painted Stairs? - Painting - DIY Chatroom Home Improvement Forum
Old 03-11-2008, 11:42 PM   #1
Rewards Points: 670
sealing bottom of painted stairs?
I am painting some wood exterior stairs, at the base of the stairs the wood rests on concrete. I plan to seal the wood against the concrete with latex (silicone added).
My two questions are:
1) will the latex bond adequately between the wood and the concrete
2) could sealing there make things worse (seal in moisture?). The area at the base of the stairs periodically has lots of moisture, during rains or when the sprinklers run.
darsunt is offline   Reply With Quote
Old 03-12-2008, 06:28 PM   #2
Pro Painter
The concrete at the bottom of the stairs should have a slight pitch to let water run off.
This would also allow water to drain away from the stairs. Sealing it up isn't usually a good way to go.
joewho is offline   Reply With Quote
Changing from carpet stairs to wood stairs DIY_user Remodeling 16 07-29-2010 07:16 PM
baseboard trim gaps on stairs beppygirl General DIY Discussions 8 02-24-2008 01:31 PM
Transitioning painted stairs to hallway and trim...HELP naromli Painting 2 01-26-2008 01:21 PM
sealing painted concrete hmmm Flooring 1 01-18-2008 04:16 AM
